Author Topic: wrong 3d polyline point  (Read 1397 times)
ssbp
« on: March 20, 2016, 08:20:02 AM »
I have prepared some code in a simple way to extrude object. I could not see anything wrong in program but when I run it, it always went wrong way.
Program takes endpoint as a first point to draw a 3d polyline. Please help.
(defun c:cw ()
(setq getaxis (getstring "Please select plane :"))
(setq picker (getpoint "Please select endpoint of baseline :"))
(setq xpoint (car picker))
(setq ycdrpicker (cdr picker))
(setq ypoint (car ycdrpicker))
(setq zcdrpicker (cdr ycdrpicker))
(setq zpoint (car zcdrpicker))
(setq zxplus (+ xpoint 0.5))
(setq zxminus (- xpoint 0.5))
(setq zyplus (+ ypoint 0.5))
(setq zyminus (- ypoint 0.5))
(setq zzplus (+ zpoint 0.5))
(setq zzminus (- zpoint 0.5))
(setq yxplus (+ xpoint 0.5))
(setq yxminus (- xpoint 0.5))
(setq yyplus (+ ypoint 0.5))
(setq yyminus (- ypoint 0.5))
(setq yzplus (+ zpoint 0.5))
(setq yzminus (- zpoint 0.5))
(setq xxplus (+ xpoint 0.5))
(setq xxminus (- xpoint 0.5))
(setq xyplus (+ ypoint 0.5))
(setq xyminus (- ypoint 0.5))
(setq xzplus (+ zpoint 0.5))
(setq xzminus (- zpoint 0.5))
(if (= getaxis "z")
   (setq firstpoint (list zxminus zyminus zpoint))
   (setq secondpoint (list zxminus zyplus zpoint))
   (setq thirdpoint (list zxplus zyplus zpoint))
   (setq fourthpoint (list zxplus zyminus zpoint))
(if (= getaxis "y")
   (setq firstpoint (list yxplus ypoint yzplus))
   (setq secondpoint (list yxplus ypoint yzminus))
   (setq thirdpoint (list yxminus ypoint yzminus))
   (setq fourthpoint (list yxminus ypoint yzplus))
(if (= getaxis "x")
   (setq firstpoint (list xpoint xyplus xzplus))
   (setq secondpoint (list xpoint xyplus xzminus))
   (setq thirdpoint (list xpoint xyminus xzminus))
   (setq fourthpoint (list xpoint xyminus xzplus))
(command "3dpoly" firstpoint secondpoint thirdpoint fourthpoint firstpoint "")
(command "extrude" pause "" "path" pause)
(command "change" "last" "" "Properties" "LAyer" "335" "")
roy_043
  • BricsCAD 18
Re: wrong 3d polyline point
« Reply #1 on: March 20, 2016, 04:42:32 PM »
Most likely the problem is cause by the use of (command ...) in combination with your OSMODE setting.
Try:
(command "3dpoly" "_non" firstpoint "_non" secondpoint ...)Why don't you use the "_close" option?
ssbp
« Reply #2 on: March 21, 2016, 11:19:44 AM »
Yes! It works. Used "close". What is "_non"? I could not find it in 3dpoly command.
Thanks Roy.
roy_043
  • BricsCAD 18
« Reply #3 on: March 21, 2016, 12:30:48 PM »
"_non" means 'Do not use osnaps for the next point', so it is not a command option.
See: http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4945.htm#WSc30cd3d5faa8f6d813d93f4ffc2d61250-7f6a
ssbp
« Reply #4 on: March 21, 2016, 01:14:55 PM »
Oh! Thanks Roy. I wasn't aware of this.
