If using Civil3D to do normal design work (Not much in 3D Rendering). How strong of a graphics card would you need?
FYI, rendering with Civil3D doesn't involve the graphics card, that only applies to dedicated visualization software like Maya or Blender.
Nothing like the top-of-line $10k Quadros is needed, a decent high-end gaming card should suffice. If you are tied to a Quadro by your box vendor, a low- to mid-range like the 2000 or 4000 series will do. Dual cards (SLI, Crossfire, etc.) are not taken advantage of. Don't try using the various shaded visual styles in the program aside from static-display viewports on drawings; use Navisworks, either Simulate or the NWNavigator plug-in, for dynamically viewing your models.
