Author Topic: LISP Challenge: Grouping items.  (Read 4937 times)
« on: May 10, 2005, 11:39:40 AM »
Write a function that given a list, will group the items in sub lists of n items.
For example, if we defined a function GroupItems, that takes two arguments, a list 'lst' and a grouping number 'n', this snippette:
(   (lambda ( / lst )
        (setq lst '(1 2 3 4 5 6 7 8 9 10))
        (foreach n lst
            (princ
                (strcat
                    "\nGrouped "
                    (itoa n)
                    " at a time: "
            (princ (GroupItems lst n))
Might produce this:
Grouped 1 at a time: ((1) (2) (3) (4) (5) (6) (7) (8) (9) (10))
Grouped 2 at a time: ((1 2) (3 4) (5 6) (7 8) (9 10))
Grouped 3 at a time: ((1 2 3) (4 5 6) (7 8 9) (10))
Grouped 4 at a time: ((1 2 3 4) (5 6 7 8) (9 10))
Grouped 5 at a time: ((1 2 3 4 5) (6 7 8 9 10))
Grouped 6 at a time: ((1 2 3 4 5 6) (7 8 9 10))
Grouped 7 at a time: ((1 2 3 4 5 6 7) (8 9 10))
Grouped 8 at a time: ((1 2 3 4 5 6 7 8) (9 10))
Grouped 9 at a time: ((1 2 3 4 5 6 7 8 9) (10))
Grouped 10 at a time: ((1 2 3 4 5 6 7 8 9 10))
Note how it might deal with lists that do not divide evenly by the grouping number 'n'.
Enjoy.
whdjr
« Reply #1 on: May 10, 2005, 03:14:53 PM »
Well...it's pretty ugly but it works:
(defun GroupItems (lst n / idx nlst lst2)
  (while lst
    (setq idx 0)
    (while (and (< idx n) (> (length lst) idx))
      (setq nlst (cons (nth idx lst) nlst)
   idx (1+ idx)
    (setq lst2 (cons (reverse nlst) lst2)
 nlst nil
 lst  (member (nth n lst) lst)
  (reverse lst2)
Output:
« Reply #2 on: May 10, 2005, 03:22:59 PM »
Looks good to me Will, thanks for stepping up. I tried it and it works, good job. :)
I've written two: One for actual use (I've actually posted it before) and one for fun; the latter I wrote today. The 'fun' one is purposely obfuscated, ala Rube Goldberg, yet it demonstrates a use of mapcar folks might not have considered before. :lol:
whdjr
« Reply #3 on: May 10, 2005, 03:28:46 PM »
My first thought was to use mapcar:
(mapcar 'list lst) but I couldn't get it to work for the different lengths so I did it the long way.  I still may go back and try it another way.
M-dub
« Reply #4 on: May 10, 2005, 03:30:13 PM »
Quote from: MP
The 'fun' one is purposely obfuscated...
Obfuscated?!?
« Reply #5 on: May 10, 2005, 07:14:16 PM »
Her's my submissions --
(defun GroupItems ( lst len / group result )
    (foreach item lst
            (eq len
                (length
                    (setq group
                        (cons item group)
            (setq
                result (cons group result)
                group  nil
    (reverse
        (mapcar 'reverse
            (if group
                (cons group result)
                result
This is merely for fun (read "not meant to be efficient", though it demonstrates a weird way to exploit mapcar) --
(defun RubeGoldbergGrouping ( lst n / len result )
    (setq len
        (   (lambda ( num div1 div2 / result )
                    (apply 'eq
                        (setq result
                            (mapcar
                               '(lambda (div) (/ num div))
                                (list div1 div2)
                    (car result)
                    (1+ (car result))
            (length lst)
            (fix n)
            (float n)
    (while
        (/= len
            (length
                (setq result
                    (cons nil result)
    (mapcar
       '(lambda ( group / result )
            (while (and lst (< (length result) n))
                (setq
                    result (cons (car lst) result)
                    lst    (cdr lst)
            (reverse result)
        result
See if you can figure out / explain how the obfuscated (link for M-Dub) Rube Goldberg variant works. Hint: the last mapcar call.
:cheesy:
« Reply #6 on: May 10, 2005, 07:43:16 PM »
My attempt.
(defun GroupItems (lst gp / newlst a sublst)
  (while lst
    (setq a      (car lst)
          lst    (cdr lst)
          sublst (cons a sublst)
    (if (or (= (length sublst) gp) (null lst))
      (setq newlst (cons (reverse sublst) newlst)
            sublst '()
  (reverse newlst)
« Reply #7 on: May 10, 2005, 09:20:09 PM »
Good one Alan. She works too. :)
I'm curious, why do you set sublst to '() when setting to nil achieves same? Is it to make the intent of your code clearer (i.e. empty list)?
« Reply #8 on: May 10, 2005, 09:33:41 PM »
'() ? Well mentally I was thinking empty list and that is what came out.
I know that nil can be a list and it's the same as '().
Not always sure why I do some things? :)
« Reply #9 on: May 10, 2005, 09:35:21 PM »
Works for me. Thanks.
