Author Topic: Line perpendicular to other line  (Read 2920 times)
carmi
« on: March 09, 2016, 01:12:10 PM »
Hi all...
I have already seen other posts here but i can not find the solution to my problem.
From the midpoint of a line (line 1), i would like to draw a perpendicular line (line 2) extending from both sides for 50 cm (type a cross).
Can you help me?
Regards
Carmi
Re: Line perpendicular to other line
« Reply #1 on: March 09, 2016, 01:16:20 PM »
Here is some pseudo-code for one possible method:
  1. (setq ang (angle <line-1-start> <line-1-end>)
  2.       mid (polar <line-1-start> ang (/ (distance <line-1-start> <line-1-end>) 2.0))
  3. )
  4. (command "_.line" "_non" (polar mid (+ ang (/ pi 2.0)) 50.0) "_non" (polar mid (- ang (/ pi 2.0)) 50.0) "")
carmi
« Reply #2 on: March 09, 2016, 01:26:18 PM »
  3. )
Its perfect  :wink:
Thank you
« Reply #3 on: March 09, 2016, 01:30:07 PM »
You're welcome!
carmi
« Reply #4 on: March 11, 2016, 05:16:59 AM »
Hi again...
This lisp, thanks to part of your code and another code, draws a double line and a center line.
(defun c:porta(/ eao)
(setvar "blipmode" 0)
(if (not cwidth)
(setq cwidth 0.0)
(prompt (strcat "\n Width beetwin line <"(rtos cwidth) ">: "))
(setq tcwidth (getreal))
(if tcwidth
(setq cwidth tcwidth)
(setq pt1 (getpoint "\nStart point... "))
(if pt1
(setq pt2 (getpoint pt1 "\nTo point... "))
(setq threshold 1
segment 0
oang nil
ofrad (getvar "filletrad")
(if (>= cwidth threshold)
(setq inrad (* 1.0 cwidth) outrad (* 2.0 cwidth))
(setq a (angle pt1 pt2)
1o1 (polar pt1 (+ a (/ pi 2.0)) (/ cwidth 2.0))
1o2 (polar pt2 (+ a (/ pi 2.0)) (/ cwidth 2.0))
ro1 (polar pt1 (- a (/ pi 2.0)) (/ cwidth 2.0))
ro2 (polar pt2 (- a (/ pi 2.0)) (/ cwidth 2.0))
(if (> segment 0)
(setq eao ea ebo eb)
(setq dimpt (polar pt1 (+ a (/ pi 2.0))(+ (/ cwidth 2.0) 1.0)))
(command "line" 1o1 1o2 "")
(setq ea (entlast))
(command "line" ro1 ro2 "")
(setq eb (entlast))
(if (and (> segment 0)(/= a oang)(/= pi (abs (- a oang))))
(setq xa (- oang a))
(if (or (<= xa (* -1.0 pi))(and (> xa 0)(< xa pi)))
(setq ra outrad
rb inrad
dimpt (polar pt1 (+ a (/ pi 2.0)) (+ (/ cwidth 2.0) 1.0)))
(setq ra inrad
rb outrad
dimpt (polar pt1 (- a (/ pi 2.0)) (+ (/ cwidth 2.0) 1.0)))
(setq ss (ssadd ea))
(setq ss (ssadd eao ss))
(setvar "filletrad" ra)
(command "fillet" (ssname ss 0)(ssname ss 1))
(setq pp1 (cdr (assoc 10 (entget ea))))
(if (> segment 0)
(setq po1 (cdr (assoc 11 (entget eao))))
(setq ss (ssadd eb))
(setq ss (ssadd ebo ss))
(setvar "filletrad" rb)
(setq ang (angle pt1 pt2)
      mid (polar pt1 ang (/ (distance pt1 pt2) 2.0))
(command "_.line" "_non" (polar mid (+ ang (/ pi 2.0)) 0.3)) "_non" (polar mid (- ang (/ pi 2.0)) 0.3)) "")
I would like to change this code so as to give users two choices:
1. Enter the distance between the two lines directly in the command bar (as it is now);
2. Enter the distance between the two lines with the mouse by clicking two points.
Can you help me?
Regards
Carmi
« Reply #5 on: March 11, 2016, 05:49:02 AM »
Change getreal to getdist
carmi
« Reply #6 on: March 12, 2016, 03:16:15 PM »
What is the command "_non"?
hmspe
« Reply #7 on: March 12, 2016, 03:29:03 PM »
_non turns off entity snaps for the next operation.
"Science is the belief in the ignorance of experts." - Richard Feynman
carmi
« Reply #8 on: March 20, 2020, 11:12:46 AM »
hi guys,
i reopen this topic for another request for help:
In the below code (completed with your help), i want to apply a default value for cwidth variable.
I tried to add this code but does not work (probably because i have "getdist") but i don't know how to solve.
(setq cwidth (getreal "Door thickness: <0.10> "))
(if (= cwidth nil) (setq cwidth 0.10))
Can you help me please?
Thank you very much
(defun c:door(/ eao)
(if (not cwidth) (setq cwidth 0))
(setq tcwidth (getdist "\nDoor thickness: "))
(if tcwidth (setq cwidth tcwidth))
(prompt (strcat "\thickness: "(rtos tcwidth) ))
(if pt1 (setq pt2 (getpoint pt1 "\nTo point... ")))
(setq threshold 1
segment 0
oang nil
ofrad (getvar "filletrad"))
(if (>= cwidth threshold) (setq inrad (* 1.0 cwidth) outrad (* 2.0 cwidth)))
ro2 (polar pt2 (- a (/ pi 2.0)) (/ cwidth 2.0)))
(if (> segment 0)
(setq dimpt (polar pt1 (+ a (/ pi 2.0))(+ (/ cwidth 2.0) 1.0))))
(setq ea (entlast))
(setq eb (entlast))
(setq ra outrad
rb inrad
(setq ra inrad
rb outrad
(if (> segment 0)
(command "fillet" (ssname ss 0)(ssname ss 1))))
(setq ang (angle pt1 pt2) mid (polar pt1 ang (/ (distance pt1 pt2) 2.0)))
(command "_.line" "_non" (polar mid (+ ang (/ pi 2.0)) (+ 0.3 (/ tcwidth 2))) "_non" (polar mid (- ang (/ pi 2.0)) (+ 0.3 (/ tcwidth 2))) ""))
BIGAL
  • 40 + years of using Autocad
« Reply #9 on: March 21, 2020, 02:10:32 AM »
The answer was in the next post have a look
(setq *moff 10)
(initget 6)
(setq tmp (getdist (strcat "\nSpecify Offset <" (vl-princ-to-string *moff) "> : ")))
