Author Topic: Dynamic block in Multileader  (Read 9132 times)
« on: March 03, 2016, 03:32:47 PM »
For the Content part of my multileader I choose a dynamic block that i created. The block has a stretch parameter in it. Once the multileader is created the block has no dynamic abilities. Is there away around this? Or is it just not possible?
Re: Dynamic block in Multileader
« Reply #1 on: March 03, 2016, 03:48:24 PM »
Maybe a picture will help. :)
« Reply #2 on: March 03, 2016, 04:21:43 PM »
pretty sure no....
as the block is now 'nested' inside the mleader definition
MSTG007
« Reply #3 on: March 03, 2016, 04:53:19 PM »
So you can do it but you have to reset the drag state, switch visibility state then stretch again?
Civil3D 2020
« Reply #4 on: March 03, 2016, 05:23:19 PM »
Since you are already using a dynamic block, how about making the leader part of the block definition, with a polar stretch parameter.
EDIT: Quick example:
« Last Edit: March 03, 2016, 05:33:21 PM by Lee Mac »
« Reply #5 on: March 04, 2016, 07:59:03 AM »
That would work out well. How did you make the leader part of that?
thanks
« Reply #6 on: March 04, 2016, 08:44:48 AM »
probably a leader inside the block...if I was guessing
« Reply #7 on: March 04, 2016, 08:53:38 AM »
Created an MLeader with the desired appearance.
Exploded the MLeader and made a block from components.
Added Linear Stretch Parameter with two grips to the annotation side of the leader.
Added Linear Stretch Parameter with one grip to the leader dogleg.
Added Polar Stretch Parameter with one grip to the leader line & arrowhead.
I can upload a drawing later if you want.
« Reply #8 on: March 04, 2016, 08:53:43 AM »
that's what i thought too. didn't work out to well for me though. LOL
« Reply #9 on: March 04, 2016, 08:54:55 AM »
Thanks Lee. Let me try it first. :)
TheCADnoob
« Reply #10 on: March 04, 2016, 10:14:02 AM »
this graphic is way more mesmerizing than it should be... time for more coffee
To boldly go where spell check has never gone before. | AutoCAD - 2016 | cadnoob.com
steve.carson
« Reply #11 on: March 04, 2016, 07:27:36 PM »
I did something similar to Lee for a callout block that we insert from the Sheetset Manager, but didn't explode the multileader. That way the leaders flip sides as you stretch them around. I added visibility states to add up to 6 leaders. It's not ideal for your block but you may be able to steal some ideas from it.
Steve
« Reply #12 on: March 05, 2016, 11:29:26 AM »
...but didn't explode the multileader. That way the leaders flip sides as you stretch them around.
Great idea Steve, thanks for sharing.
« Reply #13 on: March 07, 2016, 10:17:43 AM »
Thanks for that Steve. It took me several tries but i got my block to do what i want.
BTW, there does not seem to be a whole lot of info regarding dynamic blocks and all parameters and actions. I see a lot of technical info but no howto's. If anyone has links to share that would be nice. :)
thanks
