Author Topic: Using grread with osnap  (Read 2398 times)
Peter2
« on: March 03, 2016, 04:59:09 AM »
(Question has a low priority)
Maybe a simple question and a simple idea:
I use grread to display the coordinates of the cursor - 2 lines of code
But I want that an "osnap" is active while moving the mouse. Usually, osnap is only active when a command is active (drawing, ID ...). the idea is for example to move the cursor to a line - "osnap end" is active - grread shows me the coords of the endpoints, not of the cursor. Similar to the standard "ID" command, but "dynamically moving".
Any simple solutions?
Peter
BricsCAD V23
ribarm
  • Marko Ribar, architect
Re: Using grread with osnap
« Reply #1 on: March 03, 2016, 05:15:18 AM »
M.R. on Youtube
Stefan
« Reply #2 on: March 03, 2016, 05:17:47 AM »
Maybe this, but no osnap glyph.
  1.   (= (car (setq grp (grread T 5 0))) 5)
  2.   (setq cursor_position (cadr grp))
  3.   (setq ID_point
  4.          (cond
  5.            ((osnap cursor_position "_end")) ;"_end,_mid,_int"
  6.            (cursor_position)
  7.            )
  8.         )
  9.   (princ (strcat "\rCurrent point: " (vl-princ-to-string ID_point)))
  10.   )
Peter2
« Reply #3 on: March 03, 2016, 05:28:48 AM »
http://www.lee-mac.com/grsnap.html
Everytime when I look at Lees code I understand the difference between singing in the soccer stadium and Pavarotti.
Thanks - fine working and compact.
Peter
BricsCAD V23
cmwade77
« Reply #4 on: March 03, 2016, 05:25:24 PM »
No kidding, I agree completely, it's probably why so much of his code is scattered throughout our routines.
