Author Topic: Visibility-Add-Eng for AutoCAD 2016  (Read 3908 times)
Cuddles
« on: February 16, 2016, 04:44:40 PM »
Hello to All,
I have recently discovered that the LISP code, Visibility-Add-Eng, allowing users to add multiple visibility parameters to a dynamic block, has been updated by a user and is apparently now usable in AutoCAD 2016.
The link to the site from which it was downloaded can be found here: http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod12e.htm
Please note i have not yet tried the code for myself. From what i understand there are still some minor bugs. However, the majority of the functions are believed to work. Please refer to the weblink for further information regarding bugs and use.
Note (added 18/02/16): Use of the program requires a set procedure when making blocks with multiple visibility states. The included steps in the LISP file are not the easiest to follow. If anyone has a better, more understandable procedure, please add below for the benefit of other users. Thanks.
The LISP file is attached for download.
Cheers everyone,
Cuddles.
« Last Edit: February 17, 2016, 03:50:09 PM by Cuddles »
