Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
apply auto lisp to nested blocks (blocks sub entities)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: apply auto lisp to nested blocks (blocks sub entities) (Read 1682 times)
handasa
Newt
on:
February 09, 2016, 08:27:57 AM »
Code - Auto/Visual Lisp:
[Select]
;Change all TrueColor to AutoCAD Color Index
defun
c:all_to_aci
remove420 la e
defun
remove420
entity_list
entmod
vl-remove
assoc
420
entity_list
entity_list
while
setq
la
tblnext
"layer"
not
la
remove420
entget
tblobjname
"layer"
cdr
assoc
2
la
while
setq
e
if
e
entnext
e
entnext
remove420
entget
e
princ
i want this lisp to be applied to all objects including nested blocks entities...
any help?
thanks in advance...
Logged
ChrisCarlson
Guest
Re: apply auto lisp to nested blocks (blocks sub entities)
Reply #1 on:
February 09, 2016, 09:52:50 AM »
You'll find that almost all of these questions have been answered
https://www.theswamp.org/index.php?topic=5288.0
Also stealing snippets are bad, a quick google search will bring up a post from 2014 by Stefen that you lifted this routine from.
http://www.cadtutor.net/forum/showthread.php?88740-Change-especific-True-color-to-especific-ASC-color-by-LISP&p=608427&viewfull=1#post608427
Please provide proper credits in your routines.
Logged
handasa
Newt
Reply #2 on:
February 09, 2016, 12:07:10 PM »
iam not a lisp developer ... and i didn't say that this lisp is mine !
i found this lisp and wanna to modify it to meet my needs ...
best regards
Logged
ChrisCarlson
Guest
Reply #3 on:
February 10, 2016, 07:27:34 AM »
Anyway, check out the 3rd post in the first link I posted. It shows how to go into the block and apply a change, in the case of the other thread he changed all the colors to color index #8.
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #4 on:
February 10, 2016, 07:52:13 AM »
The OP has posted this problem 3 times (2x on this forum):
https://www.theswamp.org/index.php?topic=50890.msg560253#msg560253
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
