Author Topic: change lisp from applying to whole drawing to be applied to the selected objects  (Read 4068 times)
ChrisCarlson
Your issue starts here
  1. (setq ss (ssget "_X" (list (cons 0 "*TEXT"))))
The "_X" signifies it will grab all entities and then filter to select only *TEXT entities (RTEXT, MTEXT, TEXT).
handasa
which replace text from opened excel window in background.
the point here that this lisp process the same text many time
say i have two columns as follow
green red
red yellow
yellow orange
so if i have three texts in the drawing "green , red, yellow" the result that the three texts will be "orange" which is undesired result
any suggestions ?
