Author Topic: wxWidgets and Brx/Arx  (Read 10399 times)
It's Alive!
  • Retired
  • AKA Daniel
« on: February 02, 2016, 10:03:35 PM »
Yet another attempt at  http://www.theswamp.org/index.php?topic=31587.0
Step 1, Download wxWidgets from https://www.wxwidgets.org/downloads/   Im using 3.0.2 , which is also current as of this post
Step2, compile using the solution that matches your target 'visual studio version' in  wxWidgets-x.xx.x\build\msw. Build the libraries, not the DLLs, as were going to static link.
Step 3, in the output directory, i.e. wxWidgets-3.0.2\lib,  I inserted the compiler version in the library folder name, I.e. from  vc_x64_lib to vc110_x64_lib.
..next setting up the Arx/Brx project
« Last Edit: February 10, 2016, 12:59:13 AM by nullptr »
Retired
kdub
  • Mesozoic keyThumper
  • SuperMod
Re: wxWidgets and Brx/Arx
« Reply #1 on: February 02, 2016, 10:17:03 PM »
I notice they have DotNet binaries also
http://wxnet.sourceforge.net/binary.html
called Kerry in my other life
I don't really work crazy hours . . I just live at UTC + 13.00
#ridesober
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: February 02, 2016, 10:24:43 PM »
Step 4, Add a Windows System Variable, that points to your wxWidgets folder, I used WxArx
Step 5, Create an Arx project and add the paths to your SDK, I don’t add MFC support.
Example include paths:
$(_SDK_PATH_)\inc;$( _SDK_PATH_)\inc-$(PlatformName);$(WxArx)\Include;$(WxArx)\include\msvc
Example  library paths are:
$(_SDK_PATH_)\lib-$(PlatformName);$(WxArx)\lib\vc120_x64_lib
Define:  __WXMSW__  and  wxMSVC_VERSION_AUTO
Add dependencies to the widgets libraries you'll be using, I added this to my  StdAfx.h
Code - C++: [Select]
  1.
  2. #define __WXMSW__
  3. #define wxMSVC_VERSION_AUTO
  4.
  5. #ifdef __WXMSW__
  6. #include <wx/wx.h>
  7. #include <wx/string.h>
  8. #include <wx/xrc/xmlres.h>
  9.
  10. #pragma comment(lib, "wxbase30u.lib")
  11. #pragma comment(lib, "wxtiff.lib")
  12. #pragma comment(lib, "wxbase30u_net.lib")
  13. #pragma comment(lib, "wxscintilla.lib")
  14. #pragma comment(lib, "wxbase30u_xml.lib")
  15. #pragma comment(lib, "wxregexu.lib")
  16. #pragma comment(lib, "wxexpat.lib")
  17. #pragma comment(lib, "wxpng.lib")
  18. #pragma comment(lib, "wxjpeg.lib")
  19. #pragma comment(lib, "wxmsw30u_xrc.lib")
  20. #pragma comment(lib, "wxmsw30u_adv.lib")
  21. #pragma comment(lib, "wxmsw30u_webview.lib")
  22. #pragma comment(lib, "wxmsw30u_aui.lib")
  23. #pragma comment(lib, "wxmsw30u_stc.lib")
  24. #pragma comment(lib, "wxmsw30u_core.lib")
  25. #pragma comment(lib, "wxmsw30u_richtext.lib")
  26. #pragma comment(lib, "wxmsw30u_gl.lib")
  27. #pragma comment(lib, "wxmsw30u_ribbon.lib")
  28. #pragma comment(lib, "wxmsw30u_html.lib")
  29. #pragma comment(lib, "wxmsw30u_qa.lib")
  30. #pragma comment(lib, "wxmsw30u_media.lib")
  31. #pragma comment(lib, "wxzlib.lib")
  32. #pragma comment(lib, "wxmsw30u_propgrid.lib")
  33. #endif
  34.
  35.
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: February 02, 2016, 10:32:32 PM »
I haven't tried those yet, could be interesting!
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: February 02, 2016, 10:39:09 PM »
Next we need an application class that derives from wxApp, it’s important that we
define IMPLEMENT_APP_NO_MAIN or wxIMPLEMENT_APP_NO_MAIN ,
as this is a plug-in and we want to use the host applications messages
  1. //WxRxApp.h
  2. class WxRxApp : public wxApp
  3. {
  4. public:
  5.     virtual bool OnInit();
  6.     static bool initWxApp();
  7.     static void uninitWxApp();
  8.     static wxWindow* mainWindow();
  9. };
  10.
  1. //WxRxApp.cpp
  2. #include "stdafx.h"
  3. #include "WxRxApp.h"
  4. #include "wx/aui/aui.h"
  5.
  6. class WinFrame : public wxFrame
  7. {
  8. public:
  9.     WinFrame(HWND hwnd)
  10.     {
  11.         this->SetHWND(hwnd);
  12.         this->AdoptAttributesFromHWND();
  13.         this->m_isShown = true;
  14.         wxTopLevelWindows.Append(this);
  15.     }
  16. };
  17.
  18. static WinFrame* getMainWindow()
  19. {
  20.     static WinFrame* win = NULL;
  21.     if (win == NULL)
  22.         win = new WinFrame(adsw_acadMainWnd());
  23.     return win;
  24. }
  25.
  26. WXDLLIMPEXP_BASE void wxSetInstance(HINSTANCE hInst);
  27.
  28. bool WxRxApp::OnInit()
  29. {
  30.     wxSetInstance(acrxGetApp()->GetModuleInstance());
  31.     wxTheApp->SetTopWindow(getMainWindow());
  32.     ::wxInitAllImageHandlers();
  33.     wxXmlResource::Get()->InitAllHandlers();
  34.     return (wxTheApp->GetTopWindow() != NULL);
  35. }
  36.
  37. bool WxRxApp::initWxApp()
  38. {
  39.     if (wxInitialize())
  40.     {
  41.         wxApp::SetInstance(new WxRxApp());
  42.         if (wxTheApp && wxTheApp->CallOnInit())
  43.             return true;
  44.     }
  45.     return false;
  46. }
  47.
  48. void WxRxApp::uninitWxApp()
  49. {
  50.     wxUninitialize();
  51. }
  52.
  53. wxWindow* WxRxApp::mainWindow()
  54. {
  55.     return getMainWindow();
  56. }
  57.
  58. IMPLEMENT_APP_NO_MAIN(WxRxApp); //need this
  59. IMPLEMENT_WX_THEME_SUPPORT;
  60.
edit added WXDLLIMPEXP_BASE void wxSetInstance(HINSTANCE hInst);
« Last Edit: February 10, 2016, 12:53:00 AM by nullptr »
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: February 02, 2016, 10:46:54 PM »
Now we can initialize our wxApp in On_kInitAppMsg and uninitialize in On_kUnloadAppMsg
  1. virtual AcRx::AppRetCode On_kInitAppMsg (void *pkt) {
  2.                 // TODO: Load dependencies here
  3.
  4.                 // You *must* call On_kInitAppMsg here
  5.                 AcRx::AppRetCode retCode =AcRxArxApp::On_kInitAppMsg (pkt) ;
  6.
  7.
  8.         if (!WxRxApp::initWxApp()) //
  9.             acutPrintf(_T("\nError initializing wxWidgets\n"));
  10.
  11.                 return (retCode) ;
  12.         }
  13.
  14.         virtual AcRx::AppRetCode On_kUnloadAppMsg (void *pkt) {
  15.                 // TODO: Add your code here
  16.
  17.         WxRxApp::uninitWxApp();
  18.
  19.                 // You *must* call On_kUnloadAppMsg here
  20.                 AcRx::AppRetCode retCode =AcRxArxApp::On_kUnloadAppMsg (pkt) ;
  21.
  22.                 // TODO: Unload dependencies here
  23.
  24.                 return (retCode) ;
  25.         }
  26.
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: February 02, 2016, 11:01:01 PM »
Added sample VS2015 project to the first post.
Retired
MickD
  • (x-in)->[process]->(y-out)
« Reply #7 on: February 03, 2016, 12:37:04 AM »
Thanks Daniel! will take a look soon as BRX has been on my TODO list for a while now.
"The E in Javascript stands for 'easy'." Florin Pop tweet
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: February 03, 2016, 02:06:25 AM »
Its cool  :wink:
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: February 03, 2016, 02:08:48 AM »
Sample dialog
  1. #pragma once
  2.
  3. class MyDialog : public wxDialog
  4. {
  5. public:
  6.     MyDialog(wxWindow *parent);
  7.     void OnButton(wxCommandEvent& event);
  8.     virtual WXLRESULT MSWWindowProc(WXUINT nMsg, WXWPARAM wParam, WXLPARAM lParam);
  9. private:
  10.     wxButton *m_btnModal,
  11.              *m_btnModeless,
  12.              *m_btnDelete;
  13.
  14.     wxDECLARE_EVENT_TABLE();
  15. };
  16.
  1. #include "stdafx.h"
  2. #include "SampWxDialog1.h"
  3.
  4. wxBEGIN_EVENT_TABLE(MyDialog, wxDialog)
  5.   EVT_BUTTON(wxID_ANY, MyDialog::OnButton)
  6. wxEND_EVENT_TABLE()
  7.
  8. MyDialog::MyDialog(wxWindow *parent)
  9.     : wxDialog(parent, wxID_ANY, wxString(wxT("Modal dialog")))
  10. {
  11.     wxBoxSizer *sizerTop = new wxBoxSizer(wxHORIZONTAL);
  12.     sizerTop->Add(new wxButton(this, wxID_CLOSE), 0, wxALIGN_CENTER | wxALL, 5);
  13.     SetSizerAndFit(sizerTop);
  14.     SetEscapeId(wxID_CLOSE);
  15.     CenterOnParent();
  16. }
  17.
  18. void MyDialog::OnButton(wxCommandEvent& event)
  19. {
  20.     if (this->IsModal())
  21.         EndModal(wxID_CANCEL);
  22.     else
  23.         this->Destroy();
  24. }
  25.
  26. WXLRESULT MyDialog::MSWWindowProc(WXUINT nMsg, WXWPARAM wParam, WXLPARAM lParam)
  27. {
  28.     switch (nMsg)
  29.     {
  30.     case WM_ACAD_KEEPFOCUS:
  31.         return TRUE;
  32.     }
  33.     return wxDialog::MSWWindowProc(nMsg, wParam, lParam);
  34. }
  35.
  1.     static void WxRxProject_wxTest4(void)
  2.     {
  3.         wxWindow *win = WxRxApp::mainWindow();
  4.         if (win)
  5.         {
  6.             MyDialog  custDiag(win);
  7.             custDiag.ShowModal();
  8.         }
  9.     }
  10.
  11.     static void WxRxProject_wxTest5(void)
  12.     {
  13.         wxWindow *win = WxRxApp::mainWindow();
  14.         if (win)
  15.         {
  16.             MyDialog *custDiag = new MyDialog(win);
  17.             custDiag->Show();
  18.         }
  19.     }
  20.
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: February 03, 2016, 02:11:24 AM »
For modeless dialogs, you will need to override MSWWindowProc and handle WM_ACAD_KEEPFOCUS message
  1. virtual WXLRESULT MSWWindowProc(WXUINT nMsg, WXWPARAM wParam, WXLPARAM lParam);
  2.
  1. WXLRESULT WxArxTestDlg::MSWWindowProc( WXUINT nMsg, WXWPARAM wParam, WXLPARAM lParam )
  2. {
  3.   switch(nMsg)
  4.   {
  5.   case WM_ACAD_KEEPFOCUS:
  6.     return TRUE;
  7.   }
  8.   return wxDialog::MSWWindowProc(nMsg, wParam, lParam);
  9. }
  10.
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: February 03, 2016, 02:22:19 AM »
WxUserInteraction class is a helper class to hide modal dialogs so you can interact with the editor
  1. class WxUserInteraction
  2. {
  3.     HWND m_activeWindow;
  4.     std::vector<HWND> m_wnds;
  5. public:
  6.     WxUserInteraction();
  7.     WxUserInteraction(AcApDocument* pDocument,bool prompting);
  8.     virtual ~WxUserInteraction(void);
  9.   protected:
  10.     void userInteraction(AcApDocument* pDocument,bool prompting);
  11.     void undoUserInteraction();
  12. };
  13.
  1. WxUserInteraction::WxUserInteraction()
  2. {
  3.     userInteraction(acDocManagerPtr()->curDocument(),true);
  4. }
  5.
  6. WxUserInteraction::WxUserInteraction( AcApDocument* pDocument,bool prompting )
  7. {
  8.     userInteraction(pDocument,prompting);
  9. }
  10.
  11. WxUserInteraction::~WxUserInteraction(void)
  12. {
  13.   undoUserInteraction();
  14. }
  15.
  16. void WxUserInteraction::userInteraction(AcApDocument* pDocument,bool prompting)
  17. {
  18.     AcApDocManager* pDocMan = acDocManagerPtr();
  19.     if(pDocMan->curDocument() == pDocument)
  20.     {
  21.         pDocMan->disableDocumentActivation();
  22.         if(!prompting)
  23.             return;
  24.
  25.         HWND hwMainWnd = adsw_acadMainWnd();
  26.         if(::IsWindowEnabled(hwMainWnd) == TRUE)
  27.             return;
  28.
  29.         m_activeWindow = GetFocus();
  30.         for (HWND window = ::GetActiveWindow(); window != NULL; window = ::GetWindow(window, GW_OWNER))
  31.         {
  32.             if (window == hwMainWnd)
  33.                 break;
  34.             m_wnds.push_back(window);
  35.         }
  36.         ::EnableWindow(hwMainWnd, TRUE);
  37.         ::SetFocus(hwMainWnd);
  38.         for(size_t idx = 0 ; idx < m_wnds.size() ; idx++)
  39.         {
  40.             ::ShowWindow(m_wnds[idx],SW_HIDE);
  41.         }
  42.     }
  43. }
  44.
  45. void WxUserInteraction::undoUserInteraction()
  46. {
  47.   acDocManagerPtr()->enableDocumentActivation();
  48.   if(m_wnds.size() > 0)
  49.   {
  50.     for (std::vector<HWND>::reverse_iterator it = m_wnds.rbegin() ; it != m_wnds.rend(); ++it)
  51.     {
  52.      ::ShowWindow(*it,SW_SHOW);
  53.     }
  54.     ::EnableWindow(adsw_acadMainWnd(), FALSE);
  55.     ::SetFocus(m_activeWindow);
  56.   }
  57. }
  58.
example
  1. void WxArxTestDlg::OnButtonClick( wxCommandEvent& event )
  2. {
  3.   WxUserInteraction action;
  4.   AcGePoint3d pnt;
  5.   ads_name name = {0L, 0L};
  6.   if (acedEntSel(_T("\nSelect Entity"), name, asDblArray(pnt)) == RTNORM)
  7.   {
  8. ....
  9.   }
  10.   event.Skip();
  11. }
  12.
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: February 03, 2016, 02:27:37 AM »
Next I'll create a sample using DialogBlocks, http://www.dialogblocks.com/  8-)
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #13 on: February 03, 2016, 05:35:31 AM »
using XML Based Resource System (XRC), see http://docs.wxwidgets.org/3.0/overview_xrc.html
Code - XML: [Select]
  1. <?xml version="1.0" ?>
  2. <resource version="2.3.0.1">
  3. <object class="wxDialog" name="SimpleDialog">
  4. <title>Simple dialog</title>
  5. <object class="wxBoxSizer">
  6. <orient>wxVERTICAL</orient>
  7. <object class="sizeritem">
  8. <object class="wxTextCtrl" name="text"/>
  9. <option>1</option>
  10. <flag>wxALL|wxEXPAND</flag>
  11. <border>10</border>
  12. </object>
  13. <object class="sizeritem">
  14. <object class="wxBoxSizer">
  15. <object class="sizeritem">
  16. <object class="wxButton" name="clickme_btn">
  17. <label>Click</label>
  18. </object>
  19. <flag>wxRIGHT</flag>
  20. <border>10</border>
  21. </object>
  22. <object class="sizeritem">
  23. <object class="wxButton" name="wxID_OK">
  24. <label>OK</label>
  25. </object>
  26. <flag>wxLEFT</flag>
  27. <border>10</border>
  28. </object>
  29. <orient>wxHORIZONTAL</orient>
  30. </object>
  31. <flag>wxALL|wxALIGN_CENTRE</flag>
  32. <border>10</border>
  33. </object>
  34. </object>
  35. </object>
  36. </resource>
  37.
in On_kInitAppMsg
  1. wxXmlResource::Get()->Load("C:\\Temp\\resource.xrc");
  2.
  1.    static void WxRxProject_wxTest6(void)
  2.     {
  4.         if (win)
  5.         {
  6.             wxDialog dlg;
  7.             if(wxXmlResource::Get()->LoadDialog(&dlg, win, "SimpleDialog"))
  8.                 dlg.ShowModal();
  9.         }
  10.     }
  11.
Retired
olegog
« Reply #14 on: February 14, 2016, 07:23:49 PM »
Hi Daniel.
Your example works fine.
But.  I need put my window to CAdUiPaletteSet.  And it does not work.
I use consistency for initialisation
  1. extern "C" BOOL WINAPI DllMain(HINSTANCE hInstance, DWORD dwReason, LPVOID lpReserved)
  2. {
  3.         UNREFERENCED_PARAMETER(lpReserved) ;
  4.         if (DLL_PROCESS_ATTACH == dwReason)
  5.     {
  6.                 //WXDLLIMPEXP_BASE void wxSetInstance(HINSTANCE hInst);
  7.                 //wxSetInstance(hInstance);
  8.
  9.                 SampleDLL.AttachInstance(hInstance);
  10.                 InitAcUiDLL();
  11.
  12.                 hinst_l = hInstance;   // use this HINSTANCE
  13.         }
  14.     else if (DLL_PROCESS_DETACH == dwReason)
  15.     {
  16.                 SampleDLL.DetachInstance();
  17.         }
  18.         return TRUE;
  19. }
  20.
then
  1.     virtual AcRx::AppRetCode On_kInitAppMsg(void* pAppData)
  2.     {
  3.         AcRx::AppRetCode result = AcRxArxApp::On_kInitAppMsg(pAppData);
  4.                 startGUI();  // this my function
  5.         return result;
  6.     }
  7.
  1. void startGUI()
  2. {
  3.         wxApp::m_nCmdShow = 0;
  4.         int argc = 0;
  5.         char **argv = NULL;
  6.         if (wxEntryStart(argc, argv))
  7.         {
  8.                 WXDLLIMPEXP_BASE void wxSetInstance(HINSTANCE hInst);
  9.                 wxSetInstance(hinst_l);
  10.
  11.                 m_pPaletteSet = new CAdUiPaletteSet();
  12.                 m_pPaletteSet->Create(_T("Test BAR"), WS_OVERLAPPED | WS_DLGFRAME, CRect(0, 0, 100, 100), pWnd);
  13.                 m_pPaletteSet->EnableDocking(CBRS_ALIGN_LEFT | CBRS_ALIGN_RIGHT | CBRS_FLOATING);
  14.
  15.                 HWND hWnd4 = m_pPaletteSet->m_hWnd;
  16.                 win4 = new wxWindow();
  17.                 win4->SetHWND((WXHWND)hWnd4);
  18.                 win4->AdoptAttributesFromHWND();
  19.                 wxTopLevelWindows.Append(win4);
  20.
  21.
  22.                 m_panel = new myPanel(win4, wxID_ANY, wxPoint(0, 0), wxSize(400, 400), wxTAB_TRAVERSAL);
  23.                 butTmp = new mywxButton(m_panel, ID_TESTREPLACE, wxT("Test But"), wxDefaultPosition, wxSize(100, 100));
  24.
  25.                 m_pPaletteSet->RestoreControlBar(AFX_IDW_DOCKBAR_LEFT);
  26.                 acedGetAcadFrame()->ShowControlBar(m_pPaletteSet, TRUE, FALSE);
  27.         }
  28. }
  29.
Now it works. That is,  i have palette, where puted panel and button.
But when i clicked on panel or button i get exeption
wxWidgets Debug Alert
..\..\src\msw\button.cpp(272): assert "tlw" failed in GetTLWParentIfNotBeingDeleted(): logic error in GetTLWParentIfNotBeingDeleted()
Call stack:
[00] wxButton::MSWWindowProc                  d:\wxwidgets_3.0.2\src\msw\button.cpp:431
[01] wxWndProc                                d:\wxwidgets_3.0.2\src\msw\window.cpp:2716
[02] DispatchMessageW
[03] GetSysColorBrush
[04] GetSysColorBrush
[05] KiUserCallbackDispatcher
[06] SetFocus
[07] ImageList_SetOverlayImage
[08] ImageList_SetOverlayImage
[09] DispatchMessageW
[10] CallWindowProcW
[11] wxWindow::MSWDefWindowProc              d:\wxwidgets_3.0.2\src\msw\window.cpp:2271
[12] wxWindow::MSWWindowProc                  d:\wxwidgets_3.0.2\src\msw\window.cpp:3651
[13] wxWndProc                                d:\wxwidgets_3.0.2\src\msw\window.cpp:2716
[14] DispatchMessageW
[15] NotifyWinEvent
[16] CharLowerW
[17] 000000005C2FA9E0
[18] 000000005C22BCCA
[19] 000000005C2DFCFE
[20] 000000005C2C51F7
Do you want to stop the program?
You can also choose [Cancel] to suppress further warnings.
  1. //file button.cpp
  2.
  3. // return the top level parent window if it's not being deleted yet, otherwise
  4. // return NULL
  5. static wxTopLevelWindow *GetTLWParentIfNotBeingDeleted(wxWindow *win)
  6. {
  7.     for ( ;; )
  8.     {
  9.         // IsTopLevel() will return false for a wxTLW being deleted, so we also
  10.         // need the parent test for this case
  11.         wxWindow * const parent = win->GetParent();
  12.         if ( !parent || win->IsTopLevel() )
  13.         {
  14.             if ( win->IsBeingDeleted() )
  15.                 return NULL;
  16.
  17.             break;
  18.         }
  19.
  20.         win = parent;
  21.     }
  22.
  23.     wxASSERT_MSG( win, wxT("button without top level parent?") );
  24.
  25.     wxTopLevelWindow * const tlw = wxDynamicCast(win, wxTopLevelWindow);
  26.     wxASSERT_MSG( tlw, wxT("logic error in GetTLWParentIfNotBeingDeleted()") );  // 272
  27.
  28.     return tlw;
  29. }
  30.
String     wxASSERT_MSG( tlw, wxT("logic error in GetTLWParentIfNotBeingDeleted()") ) call
wxDefaultAssertHandler
  1. //file appbase.cpp
  2. // default assert handler
  3. static void
  4. wxDefaultAssertHandler(const wxString& file,
  5.                        int line,
  6.                        const wxString& func,
  7.                        const wxString& cond,
  8.                        const wxString& msg)
  9. {
  10.     // If this option is set, we should abort immediately when assert happens.
  11.     if ( wxSystemOptions::GetOptionInt("exit-on-assert") )
  12.         wxAbort();
  13.
  14.     // FIXME MT-unsafe
  15.     static int s_bInAssert = 0;
  16.
  17.     wxRecursionGuard guard(s_bInAssert);
  18.     if ( guard.IsInside() )
  19.     {
  20.         // can't use assert here to avoid infinite loops, so just trap
  21.         wxTrap();
  22.
  23.         return;
  24.     }
  25.
  26.     if ( !wxTheApp )
  27.     {
  28.         // by default, show the assert dialog box -- we can't customize this
  29.         // behaviour
  30.         ShowAssertDialog(file, line, func, cond, msg);
  31.     }
  32.     else
  33.     {
  34.         // let the app process it as it wants
  35.         // FIXME-UTF8: use wc_str(), not c_str(), when ANSI build is removed
  36.         wxTheApp->OnAssertFailure(file.c_str(), line, func.c_str(),
  37.                                   cond.c_str(), msg.c_str());
  38.     }
  39. }
  40.
I can't understand why i can't get event click on button.
Could  you help me?
