Author Topic: Objects disappear after regen  (Read 10706 times)
Matt__W
  • I like my water diluted.
« on: January 25, 2016, 10:55:40 AM »
I've got a DWG that has some objects that...
1) I can't select
2) don't show in a print preview
3) disappear after a REGEN
4) show up again after saving/closing/re-opening the DWG.
I've tried to recover, audit, purge, wblock but nothing works. The weird thing is that after a wblock it looks like the un-selectable, disappearing objects are in the new drawing however I still can't select them and they disappear after a regen.
I've attached the DWG. When I open it, it looks like the attached image. Can someone take a look at it and let me know if you see the same thing and if there's a way to fix it? I could always ask the surveyor to send over a new file but at this point I'm curious as to why it's doing this and how to resolve it (just I know for future reference).
Thanks.
Autodesk Expert Elite
Rob...
Re: Objects disappear after regen
« Reply #1 on: January 25, 2016, 11:00:32 AM »
I don't get the ghosts.
CAD Tech
Matt__W
« Reply #2 on: January 25, 2016, 11:02:41 AM »
Do you see anything??!?
Rob...
« Reply #3 on: January 25, 2016, 11:06:33 AM »
I didn't go to model space before. I see ghosts now and when I regen they go away.
CAD Tech
« Reply #4 on: January 25, 2016, 11:08:44 AM »
Regen & they go away .. zoom extents & they reappear  :D  .. perhaps proxy objects?
Here's a drawing with them removed.
« Last Edit: January 25, 2016, 11:17:59 AM by ronjonp »
« Reply #5 on: January 25, 2016, 11:18:41 AM »
they seem to be on locked layers...
more in a minute
« Reply #6 on: January 25, 2016, 11:20:28 AM »
Here's a drawing where you can select them :)
« Reply #7 on: January 25, 2016, 11:22:02 AM »
your ghost objects are belong to you now
Matt__W
« Reply #8 on: January 25, 2016, 12:10:08 PM »
First off, thanks.
Second... what did you guys do to fix the drawing?
« Reply #9 on: January 25, 2016, 12:11:00 PM »
First off, thanks.
I ran a MAP query....after first unlocking all layers in original
BTW
May have started life as an EaglePoint file, as the 'points' were block objects NOT civil objects.
« Reply #10 on: January 25, 2016, 12:34:18 PM »
First off, thanks.
I selected all objects (ctrl+a) then pasted into a new drawing.
To remove the points did a filter by layer PNTS*.
rkmcswain
« Reply #11 on: October 31, 2017, 09:43:57 AM »
DVIEW command, POints, set the camera and target (0,0,0 and 0,0,1).
You may find the current values include a huge "Z" value.
Then regenall.
More details: http://cadpanacea.com/wp/?p=1903
In the most recent case I ran across, this worked for MS, but when we make a viewport in a layout, these 'special' entities are still not selectable in the viewport.
But if we go back to MS, they are okay.
« Reply #12 on: October 31, 2017, 10:48:29 AM »
Quick & Dirty one off bare bones fix:
(defun c:Poof ( / ename obj x y )
    (and
        (setq ename (car (entsel)))
        (eq "VIEWPORT" (cdr (assoc 0 (entget ename))))
        (setq obj (vlax-ename->vla-object ename))
        (equal '(0.0 0.0 1.0) (vlax-get obj 'Direction))
        (setq target (vlax-get obj 'Target))
        (vlax-put obj 'target (append (mapcar 'set '(x y) (vlax-get obj 'Target)) '(0.0)))
An aside, if you're curious about the (non trivial) difference between the original dwg and the one Ronjonp posted have a look at the attached object dumps. O.o
Cheers.
« Reply #13 on: October 31, 2017, 10:54:18 AM »
Looks like I stripped out a wheee bit of data  ;D
« Reply #14 on: October 31, 2017, 10:59:47 AM »
I didn't lose any data....one of the beauties of a MAP query
ONLY    VALID   Objects are copied from the source file....
Used to be the best 'fix' for a corrupted Land Desktop file.
right up until Autodesk failed to allow MAP to see Civil 3d objects.
