Author Topic: Matching Another Mleader Attribute Values  (Read 7218 times)
cmwade77
Re: Matching Another Mleader Attribute Values
« Reply #15 on: January 28, 2016, 01:06:29 PM »
The problem is related to the alignment of the attribute.
Change (2x):
(setq TestPt1
  (polar
    (vlax-safearray->list
      (vlax-variant-value (vla-get-insertionpoint Att))
    (angle '(0 0 0) InsPt1)
    (distance '(0 0 0) InsPt1)
To:
(setq TestPt1
  (mapcar
    (vlax-get Att (if (zerop (vla-get-alignment Att)) 'insertionpoint 'textalignmentpoint))
    InsPt1
Note: Your Mleader is annotative. I expect there will be additional issues with certain anno scales.
The other issue with your method is accounting for the scale of the block when inserted into Modelspace and scaled up with DIMSCALE or manually scaled.
MSTG007
« Reply #16 on: January 28, 2016, 01:10:53 PM »
lol. Thank you for the share! Yeah.. I am still trying to fit your code into the script. Still no luck with that, keeps erroring out. But, the annotation scale is the problem. But it should work in paperspace?
Civil3D 2020
cmwade77
« Reply #17 on: January 28, 2016, 01:45:24 PM »
I have not tested it with annotative styles, but it definitely should work on any nonanotative style and should work in paperspace or modelspace, so long as dimscale is set properly.
MSTG007
« Reply #18 on: January 28, 2016, 02:30:43 PM »
I was playing around with the drawing I have uploaded, and I drew a few MLeaders in Paperspace and set the Annotation scale to None. I am hoping I did something wrong not to get it to work. lol.
Civil3D 2020
roy_043
  • BricsCAD 18
« Reply #19 on: January 28, 2016, 04:19:25 PM »
The other issue with your method...
My code is a minor improvement of *your* method. And yes, as I have mentioned before, there is an issue with block scaling and also with the textsize. Of course if there is only one attribute the solution can be much simpler.
cmwade77
« Reply #20 on: January 28, 2016, 07:37:12 PM »
I see, I am still learning with the mapcar stuff and yes when there is only one attribute, it is much easier. It would be even easier if AutoCAD would return the actual locations of the insertion points of the text somehow, then I could use the same as any of the other attribute stuff.
« Reply #21 on: March 20, 2016, 09:29:18 AM »
FWIW, I have now updated my Copy or Swap Text program to enable compatibility with Dimensions & MLeader Block Attributes.
MSTG007
« Reply #22 on: March 20, 2016, 04:02:42 PM »
Thank you so just lee for doing that!!!! Hopefully it wasn't too hard to add! Can't wait to try it tomorrow.
Civil3D 2020
« Reply #23 on: March 20, 2016, 04:05:42 PM »
You're welcome - I hope it works well in your testing.
MSTG007
« Reply #24 on: March 21, 2016, 07:51:29 AM »
Alight, I had some time to test it out. I am getting a Selected MLeader has no editable content.
Command: ctx
Formatting retained: Yes
Select source text [Settings/Exit]:
Select source text [Settings/Exit]: *Cancel*
Command:
By the way here is a same dwg. Maybe the sway the Mleader block setup is wrong?
Civil3D 2020
« Reply #25 on: March 21, 2016, 03:41:07 PM »
Command: ctx
Command:
Many thanks - I've found the bug: it was the result of a single missing character, and dependent on the order of the components within the block definition of the MLeader Attributed Block!
I will update the program shortly.
MSTG007
« Reply #26 on: March 21, 2016, 03:43:01 PM »
Woohoo. I helped lee out! Im glad you found it!
Civil3D 2020
« Reply #27 on: March 21, 2016, 06:35:53 PM »
Updated here (V1.6).
Thank you once again for your time testing the program - let me know how you get on with the new version  :-)
MSTG007
« Reply #28 on: March 22, 2016, 07:11:25 AM »
BOOM! Works! This is gonna change everything. lol! THank you again!
Civil3D 2020
« Reply #29 on: March 22, 2016, 07:38:48 AM »
Fantastic! I'm delighted that you can make use of the program  :-)
