Author Topic: Code Blocks in Dynamo  (Read 4807 times)
hudster
« on: January 20, 2016, 11:21:21 AM »
A nice article explaining the use of Code blocks in Dynamo to replace strings, formulas etc.
http://dynamobim.com/cbns-for-dummies/
Matt__W
  • I like my water diluted.
Re: Code Blocks in Dynamo
« Reply #1 on: January 20, 2016, 11:40:52 AM »
I have yet to see anything I could use Dynamo for on the MEP side of things (other than maybe extracting info to Excel). I think they'd frown upon spiral duct systems or conduits in the shape of a cow.
Don't get me wrong, I think it's great for architects to be able to perform some iterative designs quickly. It certainly has it's place.
Autodesk Expert Elite
hudster
« Reply #2 on: January 20, 2016, 11:57:20 AM »
I'm in MEP side and I can see lots of benefits, anything repetitive can be done with Dynamo.
We are currently looking at
    Copy/Monitoring Levels
    Creating views with added templates
    Creating Sheets
    Creating Worksets
    Creating Spaces from Rooms
    Schedules
Also I've used it to copy parameters from a linked architects model to an excel sheet, then copied that sheet back into our model, but populating our shared parameter information.
What I'm aiming for is a set of Dynamo scripts which can set up a project for us, quickly. all our standards in place by running a few scripts sounds good to me.
Matt__W
« Reply #3 on: January 20, 2016, 01:30:56 PM »
    Creating Sheets
    Creating Worksets
    Schedules
I have a central model template model set up that has schedules, worksets, levels already in it. Placing spaces is easy enough using the place automatically function.
Matt__W
« Reply #4 on: January 27, 2016, 01:34:53 PM »
    Creating Sheets
    Creating Worksets
    Schedules
Take a look at the AU site and search for class # AS10613. Marcello Sgambelluri has a lot of really cool examples in there. Also, search for his name on the site for other Dynamo classes he taught.
