Author Topic: How can I save SS and use in Lisp(ssget)?  (Read 4936 times)
xinxirong
  • Mosquito
« on: January 17, 2016, 03:42:36 AM »
I have a ADS function work pretty well in command mode:
command 'SAVSS can save current selection set,and when you want to use it ,for example copy,move ... etc
you can enter 'P1( or 'P2 or 'P3 or 'P4 )to get the selection set.
But ,int Lisp,for example:
(setq b (ssget)),It Prompt "cannot reenter Lisp".How can I save SS and use in Lisp(ssget)?
   static int ads_p1(void)
                long len;
                int ret=acedSSLength(DocVars.docData().myss1,&len);
                if(ret!=RTNORM)                return RTERROR;
                if (len==0)        return RTERROR;
                ret=acedRetName(DocVars.docData().myss1,RTPICKS);
                if (ret==RTNORM)
                        acutPrintf(_T("<P1 Selection set>"));
                return (RSRSLT) ;
ACED_ADSCOMMAND_ENTRY_AUTO(CBYApp, p1, true)
This is another example in vb
Dim ed As Editor =     Application.DocumentManager.MdiActiveDocument.Editor
Dim Opts As New PromptSelectionOptions()
Opts.Keywords.Add("myFence")
Opts.Keywords.Add("myWindow")
Opts.Keywords.Add("myWpoly")
Opts.Keywords.Add("myLastSel"
Opts.Keywords.Add("myPrevSel")
AddHandler Opts.KeywordInput, AddressOf handle_KeywordInput
If e.Input.CompareTo("myPrevSel") = 0 Then
  Dim res As PromptSelectionResult = ed.SelectPrevious()
  If res.Status = PromptStatus.Error Then
    Return
  End If
  Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
  Dim idarray As ObjectId() = SS.GetObjectIds()
  e.AddObjects(idarray)
End If
BlackBox
Re: How can I save SS and use in Lisp(ssget)?
« Reply #1 on: January 17, 2016, 03:44:34 PM »
Why not just call acedSSSetFirst() on your ARX SelectionSet, followed by (ssget) within your LISP to acquire the implied selection?
http://adndevblog.typepad.com/autocad/2012/05/adding-and-removing-the-entities-from-pick-first-selection-set-using-objectarx.html
Cheers
xinxirong
  • Mosquito
Re: How can I save SS and use in Lisp(ssget)cannot reenter Lisp?
« Reply #2 on: January 17, 2016, 07:46:54 PM »
(ssget) still prompt
« Reply #3 on: January 17, 2016, 08:40:23 PM »
For a selection set named ss type !ss in response to the select objects prompt.
Engineering Technologist CAD Automation Practitioner
cadanalyst@gmail.com http://cadanalyst.slack.com http://linkedin.com/in/cadanalyst
