Author Topic: Help to remove a proxy object  (Read 5365 times)
« on: January 06, 2016, 08:04:40 AM »
Normally I can overcome these problems but this one has me stumped.
Maybe because I am still using ACAD2006.
This DWG has an object that stops it from copy/paste operations.
I tried to save back to ACAD 14 but there is a hatch or something that persist.
If I have to I can ask the survey company to save back to 14 or something to remove the object but I wanted a solution I could use in the future.
Thanks in advance.
Re: Help to remove a proxy object
« Reply #1 on: January 06, 2016, 09:01:28 AM »
Here you go :)
This seemed to work for me:
  1. (defun c:byebye nil
  2.     (if (= "AcDbZombieEntity" (vla-get-objectname o))
  3.       (vla-delete o)
  4.     )
  5.     (vlax-for o2 o
  6.       (if (= "AcDbZombieEntity" (vla-get-objectname o2))
  7.         (vla-delete o2)
  8.       )
  9.     )
  10.   )
  11.   (princ)
  12. )
« Last Edit: January 06, 2016, 09:15:43 AM by ronjonp »
« Reply #2 on: January 06, 2016, 10:19:09 AM »
Ron,
How nice, a late Christmas present.  :smitten:
You made my day.
« Reply #3 on: January 06, 2016, 10:25:58 AM »
Ron,
You made my day.
Glad to help out :) .. BTW, I use your plottabs routine almost daily  8)
« Reply #4 on: January 06, 2016, 11:01:49 AM »
Yes I use plottabs daily, saves a lot of time on this plans with lots of tabs. :)
Thanks again.
ur_naz
  • Made in Ukraine
« Reply #5 on: January 07, 2016, 07:16:51 AM »
This should also help to explode or remove proxies
http://www.maestrogroup.com.ua/support/ExplodeProxy.zip
« Reply #6 on: January 07, 2016, 09:48:38 AM »
Thanks for the offering but I can not translate the Help File.
What language is it?
HasanCAD
« Reply #7 on: January 07, 2016, 11:07:56 AM »
I believe it is Russian.
VovKa
  • Ukraine
« Reply #8 on: January 07, 2016, 06:11:53 PM »
The author is a theswamp member
http://www.theswamp.org/index.php?action=profile;u=955
You can ask all your questions in person
gile
  • Marseille, France
« Reply #9 on: January 08, 2016, 03:59:19 AM »
As replies aren't strictly related to LISP, I'd also suggest ZombieKiller available on Exchange Apps.
« Reply #10 on: January 08, 2016, 08:14:06 AM »
I attempted it earlier in my search but did bot seem to work in ACAD2006
Ran the msi then opened ACAD
Command: FINDZOMBIES
Unknown command "FINDZOMBIES".  Press F1 for help.
« Last Edit: January 08, 2016, 08:18:05 AM by CAB »
« Reply #11 on: January 08, 2016, 08:20:44 AM »
Still having problems with this DWG.
« Reply #12 on: January 08, 2016, 08:43:28 AM »
All Autodesk Exchange Store apps are only compatible with AutoCAD 2012 onwards (not necessarily a restriction of the program itself, but a restriction of the Autodesk installer) - the compatibility is listed in the right-hand column.
« Reply #13 on: January 08, 2016, 09:35:42 AM »
Is this better?
« Reply #14 on: January 08, 2016, 09:48:14 AM »
Yes, that fixed it Ron.  8)
