Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
[LISP] How to set path
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [LISP] How to set path (Read 1876 times)
delkov
Guest
on:
January 03, 2016, 04:41:00 PM »
Hello everyone!
I have an lisp routine and I wish that he might set the path. (the same when you install the program -> you select the path in window and then click "OK")
And assign a variable this path.
Is it possible?
Many thanks.
Logged
delkov
Guest
Re: [LISP] How to set path
Reply #1 on:
January 04, 2016, 04:34:05 AM »
I want to obtain path by select folder and click OK (like at screen).
After, assign variable this path
What command I must to write to call this method?
Logged
bilançikur
Newt
Reply #2 on:
January 04, 2016, 04:36:11 AM »
Sure it is possible, why don't you start by giving us the code where you may want your modification?
Without it it is just plain guessing....
But this may get you started:
http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-AD65DF88-5218-4655-B877-B4D33B9FB6D1.htm,topicNumber=d30e615733
This...
(vl-filename-directory filename)
Logged
delkov
Guest
Reply #3 on:
January 04, 2016, 04:49:20 AM »
Thanks, one more solution by Lee-Mac:
http://www.lee-mac.com/directorydialog.html
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
