Author Topic: [challenge] Sierpinski triangle  (Read 6811 times)
gile
  • Marseille, France
« on: January 01, 2016, 06:01:29 PM »
The goal is to draw a Sierpinski triangle.
The paramters should be the boundary triangle and a number of iterations (10 seems to be enough as upper limit with LISP).
Here's an example with two different command inputs.
Re: [challenge] Sierpinski triangle
« Reply #1 on: January 01, 2016, 06:17:46 PM »
Here's an old take on the construction of the Sierpinski triangle from the perspective of Iterated Function Systems (IFS):
Effectively yielding an infinite number of iterations, constructed simultaneously.
gile
  • Marseille, France
« Reply #2 on: January 01, 2016, 06:31:19 PM »
Awesome, Lee (as usual).
I didn't see it before.
« Reply #3 on: January 01, 2016, 06:37:56 PM »
Many thanks gile - though, it doesn't quite meet the exacting specifications of your challenge.  :evil:
Should the triangle be constructed from 3DFACE, TRACE, HATCH, or LWPOLYLINE entities?
gile
  • Marseille, France
« Reply #4 on: January 01, 2016, 06:48:55 PM »
As you want, the entity type doesn't matter so much. In the shown example they are SOLID.
I posted in the LISP forum, but all languages are welcome.
« Reply #5 on: January 02, 2016, 04:53:34 AM »
Here's my first draft:
  1. (defun sierpinski ( p1 p2 p3 n / m1 m2 m3 )
  2.     (if (< n 1)
  3.         (entmake (list '(0 . "SOLID") (cons 10 p1) (cons 11 p2) (cons 12 p3) (cons 13 p3)))
  4.         (progn
  5.             (setq m1 (mid p1 p2)
  6.                   m2 (mid p1 p3)
  7.                   m3 (mid p2 p3)
  8.             )
  9.             (mapcar '(lambda ( a b c ) (sierpinski a b c (1- n)))
  10.                 (list p1 m1 m2)
  11.                 (list m1 p2 m3)
  12.                 (list m2 m3 p3)
  13.             )
  14.         )
  15.     )
  16. )
  17. (defun mid ( a b )
  18.     (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) a b)
  19. )
To test:
  1. (defun c:test1 ( / p1 p2 p3 )
  2.     (if (and (setq p1 (getpoint "\nSpecify 1st point of triangle: "))
  3.              (setq p2 (getpoint "\nSpecify 2nd point of triangle: " p1))
  4.              (setq p3 (getpoint "\nSpecify 3rd point of triangle: " p1))
  5.         )
  6.         (sierpinski
  7.             (trans p1 1 0)
  8.             (trans p2 1 0)
  9.             (trans p3 1 0)
  10.             (progn (initget 6) (cond ((getint "\nSpecify number of iterations <5>: ")) (5)))
  11.         )
  12.     )
  13.     (princ)
  14. )
  1. (defun c:test2 ( / cen rad )
  2.     (if (and (setq cen (getpoint "\nSpecify center: "))
  3.              (setq rad (getdist  "\nSpecify radius: " cen))
  4.         )
  5.         (sierpinski
  6.             (trans (polar cen (/ (* 3.0  pi) 6.0) rad) 1 0)
  7.             (trans (polar cen (/ (* 7.0  pi) 6.0) rad) 1 0)
  8.             (trans (polar cen (/ (* 11.0 pi) 6.0) rad) 1 0)
  9.             (progn (initget 6) (cond ((getint "\nSpecify number of iterations <5>: ")) (5)))
  10.         )
  11.     )
  12.     (princ)
  13. )
« Last Edit: January 02, 2016, 05:00:17 AM by Lee Mac »
Patriiick
  • Mosquito
« Reply #6 on: January 02, 2016, 06:26:33 AM »
Now I know what you, guys, are doing while I drink champagne for the new year!  :-D
Happy new year!
« Reply #7 on: January 02, 2016, 07:31:04 AM »
Happy new year!
Happy New Year!  :-D
Here's another, to show the progression:
  1. (defun c:test ( / itr lst pt1 pt2 pt3 tmp )
  2.     (if (and (setq pt1 (getpoint "\nSpecify 1st point of triangle: "))
  3.              (setq pt2 (getpoint "\nSpecify 2nd point of triangle: " pt1))
  4.              (setq pt3 (getpoint "\nSpecify 3rd point of triangle: " pt1))
  5.         )
  6.         (progn
  7.             (foreach sym '(pt1 pt2 pt3) (set sym (trans (eval sym) 1 0)))
  8.             (setq tmp (getvar 'millisecs)
  9.                   lst (sierpinski pt1 pt2 pt3 1)
  10.                   tmp (- (getvar 'millisecs) tmp)
  11.                   itr 2
  12.             )
  13.             (while
  14.                 (progn (initget "Yes No")
  15.                     (/= "No"
  16.                         (getkword
  17.                             (strcat
  18.                                 "\nThe next iteration will generate "
  19.                                 (rtos (expt 3.0 itr) 2 0)
  20.                                 " objects in approx. "
  21.                                 (rtos (* tmp 0.006) 2 3)
  22.                                 " seconds.\nProceed? [Yes/No] <Yes>: "
  23.                             )
  24.                         )
  25.                     )
  26.                 )
  27.                 (setq tmp (getvar 'millisecs))
  28.                 (foreach ent lst (entdel ent))
  29.                 (setq lst (sierpinski pt1 pt2 pt3 itr)
  30.                       tmp (- (getvar 'millisecs) tmp)
  31.                       itr (1+ itr)
  32.                 )
  33.             )
  34.         )
  35.     )
  36.     (princ)
  37. )
  38. (defun sierpinski ( p1 p2 p3 n / m1 m2 m3 )
  39.     (if (< n 1)
  40.         (list (entmakex (list '(0 . "SOLID") (cons 10 p1) (cons 11 p2) (cons 12 p3) (cons 13 p3))))
  41.         (progn
  42.             (setq m1 (mid p1 p2)
  43.                   m2 (mid p1 p3)
  44.                   m3 (mid p2 p3)
  45.             )
  46.             (apply 'append
  47.                 (mapcar '(lambda ( a b c ) (sierpinski a b c (1- n)))
  48.                     (list p1 m1 m2)
  49.                     (list m1 p2 m3)
  50.                     (list m2 m3 p3)
  51.                 )
  52.             )
  53.         )
  54.     )
  55. )
  56. (defun mid ( a b )
  57.     (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) a b)
  58. )
gile
  • Marseille, France
« Reply #8 on: January 02, 2016, 11:25:16 AM »
Nice Lee.
My first attempt was written in F#, using a functional style.
It's quite close to the first one posted by Lee except it uses mutual recursion instead of recursive calls within a mapcar expression. I'd post the LISP equivalent if no one do it before.
Code - F#: [Select]
  1. module SierpinskiChallenge
  2.
  3. open Autodesk.AutoCAD.DatabaseServices
  4. open Autodesk.AutoCAD.EditorInput
  5. open Autodesk.AutoCAD.Geometry
  6. open Autodesk.AutoCAD.Runtime
  7.
  8. type AcAp = Autodesk.AutoCAD.ApplicationServices.Application
  9.
  10. let drawSierpinski nbi p1 p2 p3 =
  11.     let db = AcAp.DocumentManager.MdiActiveDocument.Database
  12.     use tr = db.TransactionManager.StartTransaction()
  13.     let cSpace = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) :?> BlockTableRecord
  14.
  15.     let draw p1 p2 p3 =
  16.         let s = new Solid(p1, p2, p3)
  17.         cSpace.AppendEntity(s) |> ignore
  18.         tr.AddNewlyCreatedDBObject(s, true)
  19.
  20.     let mid (p1 : Point3d) p2 = p1 + (p2 - p1) / 2.0
  21.
  22.     let rec loop i p1 p2 p3 =
  23.         if i > 0 then fract (i - 1) p1 p2 p3
  24.         else draw p1 p2 p3
  25.
  26.     and fract i p1 p2 p3 =
  27.         let m1, m2, m3 = mid p1 p2, mid p2 p3, mid p3 p1
  28.         loop i p1 m1 m3
  29.         loop i m1 p2 m2
  30.         loop i m3 m2 p3
  31.
  32.     loop nbi p1 p2 p3
  33.     tr.Commit()
  34.
  35. [<CommandMethod("CMD1")>]
  36. let cmd1() =
  37.     let ed = AcAp.DocumentManager.MdiActiveDocument.Editor
  38.     let ppr = ed.GetPoint("\nCenter: ")
  39.     if ppr.Status = PromptStatus.OK then
  40.         let cen = ppr.Value
  41.         let pdo = PromptDistanceOptions("\nRadius: ", BasePoint = cen, UseBasePoint = true)
  42.         let pdr = ed.GetDistance(pdo)
  43.         if pdr.Status = PromptStatus.OK then
  44.             let pio =
  45.                 PromptIntegerOptions("\nNumber of iterations: ", LowerLimit = 1, UpperLimit = 12, DefaultValue = 8)
  46.             let pir = ed.GetInteger(pio)
  47.             if pir.Status = PromptStatus.OK then
  48.                 let rad = pdr.Value
  49.                 let cen = cen.TransformBy(ed.CurrentUserCoordinateSystem)
  50.                 let p1 = cen + Vector3d(rad * -sqrt 0.75, rad * -0.5, 0.0)
  51.                 let p2 = cen + Vector3d(rad * sqrt 0.75, rad * -0.5, 0.0)
  52.                 let p3 = cen + Vector3d(0.0, rad, 0.0)
  53.                 drawSierpinski pir.Value p1 p2 p3
  54.
  55. [<CommandMethod("CMD2")>]
  56. let cmd2() =
  57.     let ed = AcAp.DocumentManager.MdiActiveDocument.Editor
  58.     let ppo = PromptPointOptions("\nFirst point: ")
  59.     let ppr = ed.GetPoint(ppo)
  60.     if ppr.Status = PromptStatus.OK then
  61.         let p1 = ppr.Value
  62.         ppo.UseBasePoint <- true
  63.         ppo.BasePoint <- p1
  64.         ppo.Message <- "\nSecond point: "
  65.         let ppr = ed.GetPoint(ppo)
  66.         if ppr.Status = PromptStatus.OK then
  67.             let p2 = ppr.Value
  68.             ppo.Message <- "\nThird point: "
  69.             let ppr = ed.GetPoint(ppo)
  70.             if ppr.Status = PromptStatus.OK then
  71.                 let p3 = ppr.Value
  72.                 let pio =
  73.                     PromptIntegerOptions("\nNumber of iterations: ", LowerLimit = 1, UpperLimit = 12, DefaultValue = 8)
  74.                 let pir = ed.GetInteger(pio)
  75.                 if pir.Status = PromptStatus.OK then
  76.                     let ucs = ed.CurrentUserCoordinateSystem
  77.                     drawSierpinski pir.Value (p1.TransformBy(ucs)) (p2.TransformBy(ucs)) (p3.TransformBy(ucs))
gile
  • Marseille, France
« Reply #9 on: January 02, 2016, 11:38:52 AM »
As the number of iterations is known, the computation can be done iteratively.
I'd post a LISP iterative version if no one do it before (with LISP, it should run faster than the recursive one).
Here's a C# implementation using an OOP and imperative (procedural) syle.
The Triangle and SierpinskiTriangle classes provide properties and methods to draw the result.
Code - C#: [Select]
  1. using Autodesk.AutoCAD.DatabaseServices;
  2. using Autodesk.AutoCAD.EditorInput;
  3. using Autodesk.AutoCAD.Geometry;
  4. using Autodesk.AutoCAD.Runtime;
  5. using System.Collections.Generic;
  6. using static System.Math;
  7. using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
  8.
  9. namespace SierpinskiTriangleChallenge
  10. {
  11.     class Triangle
  12.     {
  13.         Point3d p1, p2, p3;
  14.
  15.         public Triangle(Point3d p1, Point3d p2, Point3d p3)
  16.         {
  17.             this.p1 = p1;
  18.             this.p2 = p2;
  19.             this.p3 = p3;
  20.         }
  21.
  22.         public Triangle(Point3d center, double radius)
  23.             : this(center + new Vector3d(0.0, radius, 0.0),
  24.                    center + new Vector3d(radius * -Sqrt(0.75), radius * -0.5, 0.0),
  25.                    center + new Vector3d(radius * Sqrt(0.75), radius * -0.5, 0.0))
  26.         { }
  27.
  28.         public Point3d P1 => p1;
  29.         public Vector3d V1 => p1.GetVectorTo(p2);
  30.         public Vector3d V2 => p1.GetVectorTo(p3);
  31.
  32.         public IEnumerable<Triangle> Copy(double d)
  33.         {
  34.             yield return new Triangle(p1 + V1 * d, p2 + V1 * d, p3 + V1 * d);
  35.             yield return new Triangle(p1 + V2 * d, p2 + V2 * d, p3 + V2 * d);
  36.         }
  37.
  38.         public void Draw(BlockTableRecord btr, Transaction tr)
  39.         {
  40.             var solid = new Solid(p1, p2, p3);
  41.             btr.AppendEntity(solid);
  42.             tr.AddNewlyCreatedDBObject(solid, true);
  43.         }
  44.     }
  45.
  46.     class SierpinskiTriangle
  47.     {
  48.         List<Triangle> triangles;
  49.
  50.         public SierpinskiTriangle(int numIterations, Triangle boundary)
  51.         {
  52.             var num = Pow(2.0, numIterations);
  53.             var first = new Triangle(
  54.                 boundary.P1,
  55.                 boundary.P1 + boundary.V1 / num,
  56.                 boundary.P1 + boundary.V2 / num);
  57.             triangles = new List<Triangle>();
  58.             triangles.Add(first);
  59.             for (int i = 0; i < numIterations; i++)
  60.             {
  61.                 var tmp = new List<Triangle>();
  62.                 foreach (var triangle in triangles)
  63.                     tmp.AddRange(triangle.Copy(Pow(2.0, i)));
  64.                 triangles.AddRange(tmp);
  65.             }
  66.         }
  67.
  68.         public void Draw()
  69.         {
  70.             var db = HostApplicationServices.WorkingDatabase;
  71.             using (var tr = db.TransactionManager.StartTransaction())
  72.             {
  73.                 var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  74.                 foreach (var triangle in triangles)
  75.                     triangle.Draw(curSpace, tr);
  76.                 tr.Commit();
  77.             }
  78.         }
  79.     }
  80.
  81.     public class Commands
  82.     {
  83.         [CommandMethod("TEST1")]
  84.         public void Test1()
  85.         {
  86.             var ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
  87.             var ppr = ed.GetPoint("\nCenter: ");
  88.             if (ppr.Status != PromptStatus.OK)
  89.                 return;
  90.             var center = ppr.Value;
  91.             var pdo = new PromptDistanceOptions("\nRadius: ")
  92.             { UseBasePoint = true, BasePoint = center };
  93.             var pdr = ed.GetDistance(pdo);
  94.             if (pdr.Status != PromptStatus.OK)
  95.                 return;
  96.             var pio = new PromptIntegerOptions("\nNumber of iterations: ")
  97.             { LowerLimit = 1, UpperLimit = 12, DefaultValue = 8 };
  98.             var pir = ed.GetInteger(pio);
  99.             if (pir.Status != PromptStatus.OK)
  100.                 return;
  101.             var ucs = ed.CurrentUserCoordinateSystem;
  102.             var boundary = new Triangle(center.TransformBy(ucs), pdr.Value);
  103.             var sierpinski = new SierpinskiTriangle(pir.Value, boundary);
  104.             sierpinski.Draw();
  105.         }
  106.
  107.         [CommandMethod("TEST2")]
  108.         public void Test22()
  109.         {
  110.             var ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
  111.             var ppo = new PromptPointOptions("\nFirst point: ");
  112.             var ppr = ed.GetPoint(ppo);
  113.             if (ppr.Status != PromptStatus.OK)
  114.                 return;
  115.             Point3d p1 = ppr.Value;
  116.             ppo.Message = ("\nSecond point: ");
  117.             ppo.BasePoint = p1;
  118.             ppo.UseBasePoint = true;
  119.             ppr = ed.GetPoint(ppo);
  120.             if (ppr.Status != PromptStatus.OK)
  121.                 return;
  122.             Point3d p2 = ppr.Value;
  123.             ppo.Message = ("\nThird point: ");
  124.             ppr = ed.GetPoint(ppo);
  125.             if (ppr.Status != PromptStatus.OK)
  126.                 return;
  127.             Point3d p3 = ppr.Value;
  128.             var pio = new PromptIntegerOptions("\nNumber of iterations: ")
  129.             { LowerLimit = 1, UpperLimit = 12, DefaultValue = 8 };
  130.             var pir = ed.GetInteger(pio);
  131.             if (pir.Status != PromptStatus.OK)
  132.                 return;
  133.             var ucs = ed.CurrentUserCoordinateSystem;
  134.             var boundary = new Triangle(p1.TransformBy(ucs), p2.TransformBy(ucs), p3.TransformBy(ucs));
  135.             var sierpinski = new SierpinskiTriangle(pir.Value, boundary);
  136.             sierpinski.Draw();
  137.         }
  138.     }
  139. }
  140.
« Last Edit: January 02, 2016, 12:03:52 PM by gile »
« Reply #10 on: January 02, 2016, 02:06:56 PM »
Nice one gile  :-)
Here is a 3D version, though the code is becoming cumbersome:
  1. (defun c:test ( / itr lst pt1 pt2 pt3 pt4 tmp )
  2.     (setq pt1'( 0.0 0.0 1.5)
  3.           pt2'( 0.0 1.0 0.0)
  4.           pt3'( 0.866025 -0.5 0.0)
  5.           pt4'(-0.866025 -0.5 0.0)
  6.           tmp (getvar 'millisecs)
  7.           lst (sierpinski-3D pt1 pt2 pt3 pt4 1)
  8.           tmp (- (getvar 'millisecs) tmp)
  9.           itr 2
  10.     )
  11.     (command "_.zoom" "_e")
  12.     (while
  13.         (progn (initget "Yes No")
  14.             (/= "No"
  15.                 (getkword
  16.                     (strcat
  17.                         "\nThe next iteration will generate "
  18.                         (rtos (expt 4.0 (1+ itr)) 2 0)
  19.                         " objects in approx. "
  20.                         (rtos (* tmp 0.006) 2 3)
  21.                         " seconds.\nProceed? [Yes/No] <Yes>: "
  22.                     )
  23.                 )
  24.             )
  25.         )
  26.         (setq tmp (getvar 'millisecs))
  27.         (foreach ent lst (entdel ent))
  28.         (setq lst (sierpinski-3D pt1 pt2 pt3 pt4 itr)
  29.               tmp (- (getvar 'millisecs) tmp)
  30.               itr (1+ itr)
  31.         )
  32.     )
  33.     (princ)
  34. )
  35. (defun sierpinski-3D ( p1 p2 p3 p4 n / m1 m2 m3 m4 m5 m6 )
  36.     (if (< n 1)
  37.         (progn
  38.             (mapcar
  39.                '(lambda ( a b c )
  40.                     (entmakex
  41.                         (cons '(0 . "3DFACE")
  42.                             (mapcar 'cons '(10 11 12 13) (list a b c c))
  43.                         )
  44.                     )
  45.                 )
  46.                 (list p1 p1 p1 p2)
  47.                 (list p2 p3 p2 p3)
  48.                 (list p3 p4 p4 p4)
  49.             )
  50.         )
  51.         (progn
  52.             (setq m1 (mid p1 p2)
  53.                   m2 (mid p1 p3)
  54.                   m3 (mid p1 p4)
  55.                   m4 (mid p2 p3)
  56.                   m5 (mid p2 p4)
  57.                   m6 (mid p3 p4)
  58.             )
  59.             (apply 'append
  60.                 (mapcar '(lambda ( a b c d ) (sierpinski-3D a b c d (1- n)))
  61.                     (list p1 m1 m2 m3)
  62.                     (list m1 p2 m4 m5)
  63.                     (list m2 m4 p3 m6)
  64.                     (list m3 m5 m6 p4)
  65.                 )
  66.             )
  67.         )
  68.     )
  69. )
  70. (defun mid ( a b )
  71.     (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) a b)
  72. )
gile
  • Marseille, France
« Reply #11 on: January 02, 2016, 02:45:43 PM »
Not so "cumbersome".
Very nice.
« Reply #12 on: January 02, 2016, 06:59:49 PM »
Thank you gile  :-)
Stefan
« Reply #13 on: January 03, 2016, 11:54:57 AM »
Hi all and a Happy New Year!
  1. (defun c:test ( / f s p1 p2 p3 n a12 a13 d12 d13 i doit)
  2.
  3.   (defun f (i / d)
  4.     (setq d (expt 2 i))
  5.     (list p1 (polar p1 a12 (* d12 d)) (polar p1 a13 (* d13 d)))
  6.     )
  7.
  8.   (defun s ( / p)
  9.     (setq p (f 0))
  10.     (entmake (cons '(0 . "SOLID") (mapcar 'cons '(10 11 12 13) (cons (car p) p))))
  11.     )
  12.
  13.   (if
  14.     (and
  15.       (setq p1 (getpoint "\nFirst point: "))
  16.       (setq p2 (getpoint p1 "\nSecond point: "))
  17.       (setq p3 (getpoint p1 "\nThird point: "))
  18.       (progn
  19.         (initget 7)
  20.         (setq n (getint "\nIterations: "))
  21.         )
  22.       (setq p1 (trans p1 1 0)
  23.             p2 (trans p2 1 0)
  24.             p3 (trans p3 1 0)
  25.             a12 (angle p1 p2)
  26.             a13 (angle p1 p3)
  27.             d12 (/ (distance p1 p2) (expt 2 n))
  28.             d13 (/ (distance p1 p3) (expt 2 n))
  29.             i -1
  30.             doit '(s)
  31.             )
  32.       )
  33.     (eval
  34.       (repeat n
  35.         (setq doit (list 'foreach 'p1 (list 'f (setq i (1+ i))) doit))
  36.       )
  37.     )
  38.   )
  39.   (princ)
  40. )
gile
  • Marseille, France
« Reply #14 on: January 03, 2016, 12:21:20 PM »
Hi Stefan, nice one !
This is the iterative way I was thinking of. It should run about 2 times faster than the recursive way.
Here's what I wrote in LISP.
The functional way (mutual recursion closed to the first reply of Lee)
  1. (defun SierpinskiRecursive (p1 p2 p3 nbi / mid fract loop)
  2.
  3.   (defun mid (p1 p2)
  4.     (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.)) p1 p2)
  5.   )
  6.
  7.   (defun fract (n p1 p2 p3)
  8.     (loop n (mid p1 p2) p2 (mid p2 p3))
  9.     (loop n (mid p3 p1) (mid p2 p3) p3)
  10.     (loop n p1 (mid p1 p2) (mid p3 p1))
  11.   )
  12.
  13.   (defun loop (n p1 p2 p3)
  14.     (if (< 0 n)
  15.       (fract (1- n) p1 p2 p3)
  16.       (drawTriangle p1 p2 p3)
  17.     )
  18.   )
  19.
  20.   (loop nbi p1 p2 p3)
  21. )
the imperative way (iterative, very closed to Stefan's reply)
  1. (defun SierpinskiIterative (p1 p2 p3 nbi / a1 a2 d1 d2 lst)
  2.   (setq a1  (angle p1 p2)
  3.         a2  (angle p1 p3)
  4.         d1  (/ (distance p1 p2) (expt 2 nbi))
  5.         d2  (/ (distance p2 p3) (expt 2 nbi))
  6.         lst (list (list p1 (polar p1 a1 d1) (polar p1 a2 d2)))
  7.   )
  8.   (repeat nbi
  9.     (foreach l lst
  10.       (setq lst (vl-list*
  11.                   (mapcar '(lambda (p) (polar p a1 d1)) l)
  12.                   (mapcar '(lambda (p) (polar p a2 d2)) l)
  13.                   lst
  14.                 )
  15.       )
  16.     )
  17.     (setq d1  (* 2 d1)
  18.           d2  (* 2 d2)
  19.     )
  20.   )
  21.   (foreach l lst (drawTriangle (car l) (cadr l) (caddr l)))
  22. )
Helpers and testing command functions
  1. (defun drawTriangle (p1 p2 p3)
  2.     (list
  3.       '(0 . "SOLID")
  4.       (cons 10 p1)
  5.       (cons 11 p2)
  6.       (cons 12 p3)
  7.       (cons 13 p3)
  8.     )
  9.   )
  10. )
  11.
  12. (defun centerRadius (drawSierpinski / cen rad nbi ms)
  13.   (and
  14.     (setq cen (getpoint "\nCenter: "))
  15.     (setq rad (getdist cen "\nRadius: "))
  16.     (setq nbi (getint "\nNumber of iterations: "))
  17.     (setq ms (getvar 'millisecs))
  18.     (setq cen (trans cen 1 0))
  19.     (apply
  20.       drawSierpinski
  21.       (list
  22.         (polar cen (/ pi 2) rad)
  23.         (polar cen (/ (* 7 pi) 6) rad)
  24.         (polar cen (/ (* 11 pi) 6) rad)
  25.         nbi
  26.       )
  27.     )
  28.     (setq ms (- (getvar 'millisecs) ms))
  29.     (princ (strcat "\nElapsed milliseconds: " (itoa ms)))
  30.   )
  31.   (princ)
  32. )
  33.
  34. (defun threePoints (drawSierpinski / p1 p2 p3 nbi ms)
  35.   (and
  36.     (setq p1 (getpoint "\nFirst point: "))
  37.     (setq p2 (getpoint p1 "\nSecond point:  "))
  38.     (setq p3 (getpoint p1 "\nThird point:  "))
  39.     (setq nbi (getint "\nNumber of iterations: "))
  40.     (setq ms (getvar 'millisecs))
  41.     (apply
  42.       drawSierpinski
  43.       (list
  44.         (trans p1 1 0)
  45.         (trans p2 1 0)
  46.         (trans p3 1 0)
  47.         nbi
  48.       )
  49.     )
  50.     (setq ms (- (getvar 'millisecs) ms))
  51.     (princ (strcat "\nElapsed milliseconds: " (itoa ms)))
  52.   )
  53.   (princ)
  54. )
  55.
  56. (defun c:ITER1 () (centerRadius 'SierpinskiIterative))
  57.
  58. (defun c:REC1 () (centerRadius 'SierpinskiRecursive))
  59.
  60. (defun c:ITER2 () (threePoints 'SierpinskiIterative))
  61.
  62. (defun c:REC2 () (threePoints 'SierpinskiRecursive))
« Last Edit: January 03, 2016, 01:16:31 PM by gile »
