Author Topic: Wire Sizing Calculator - ASP.NET 5, anglar etc...  (Read 2738 times)
Jeff H
« on: December 22, 2015, 11:22:06 AM »
If anyone has questions ask away but started putting tools on site to look at latest asp.net and its a total rewrite and different. Set up to be cross platform and much lighter and uses tools that are popular by web developers.
If the site has not been used a little while it has start up a new instance since it is in testing.
http://hpadwebapplication.azurewebsites.net/WireSizingData/WireSizeCalculator
I really like angular how all the updating is happening on client side and so easy quickly bind.
http://hpadwebapplication.azurewebsites.net/Home/VoltAmps
MexicanCustard
Re: Wire Sizing Calculator - ASP.NET 5, anglar etc...
« Reply #1 on: December 22, 2015, 01:06:58 PM »
Yeah, I really like the new features of ASP.NET 5 and Entity Framework 7. Plural Sight released a great course on it last month.  I like the startup.cs way of doing it.  Adding functionality is as easy as app.UseMvc() or app.UseIdentity().
Haven't used Angular 2 but Angular has been a great tool since Google released it.
Looking forward to checking those apps out.
MickD
« Reply #2 on: December 22, 2015, 04:29:34 PM »
Nice work Jeff!
J.R.R. Tolkien
Jeff H
Jeff H
« Reply #4 on: December 23, 2015, 06:18:35 PM »
If you nothing better to do you can least click on switch schematic
http://hpadwebapplication.azurewebsites.net/Diagram/Diagram2
« Reply #5 on: December 23, 2015, 07:06:35 PM »
That has a certain Jeffishness about it :)
MickD
« Reply #6 on: December 23, 2015, 10:56:47 PM »
 :thinking:  wasn't me :)
J.R.R. Tolkien
Jeff H
« Reply #7 on: December 24, 2015, 01:16:54 AM »
Atook
  • AKA Tim
« Reply #8 on: December 24, 2015, 01:10:52 PM »
 :2funny: That would make a great easter egg in a logo or something!
Great site Jeff, very clean. I like that you show your reference tables.
Jeff H
« Reply #9 on: January 11, 2016, 10:55:20 AM »
http://hpadwebapplication.azurewebsites.net/Diagram/Diagram5
Does not work in IE
They overlap each other so need to move around to see better but start closing switches and should light up. I found out jquery has hiccup for Internet Explorer when dealing with SVG so have to go through and edit every a class selection  made on SVG element. So only Chrome and FireFox working.
Oh the reason the are hooked up the way they are and not in order is because using actual arrangement on a site to test it.
Jeff H
« Reply #10 on: January 12, 2016, 10:14:45 AM »
Working 30 mins here and there but works in IE now
http://hpadwebapplication.azurewebsites.net/Diagram/Diagram6
Every thing I look at I end up having to learn some library or web technology.
