Author Topic: 3DSOLID edge not sharp in PDF printing  (Read 3321 times)
HasanCAD
« on: December 11, 2015, 02:43:25 AM »
I created 3DSOLID put when print to PDF the edges not smooth.
Please advice how to make smooth
these snapshot for visual style and PDF printout
lamarn
Re: 3DSOLID edge not sharp in PDF printing
« Reply #1 on: December 11, 2015, 04:49:05 AM »
I think This is more about how to set paper pagesetup.
Will probably help if you choose A0 as format with maximum resolution. That help for me most of the time..
Rob...
« Reply #2 on: December 11, 2015, 06:45:11 AM »
Paper size doesn't directly affect print quality.
The resolution setting for PDF would be in the plotter/printer settings.
CAD Tech
HasanCAD
« Reply #3 on: December 11, 2015, 07:35:22 AM »
Thanks lamarn Yes A0 gives better resolution.
Thanks Rob... I'll change the resolution too
lamarn
« Reply #4 on: December 11, 2015, 08:20:05 AM »
Of course the printed papersize does affect the quality. If the dpi is the same with a bigger size you get more dots for the whole print. Relatively it indeed does not effect dpi, I think that is what you mean..
Rob...
« Reply #5 on: December 11, 2015, 08:29:52 AM »
By definition, the resolution, DPI, is dots per inch. If you are generating a PDF at 8.5x11 or 36x48 with 300 DPI, the resolution is the same on both sizes. Just because the larger sheet has more dots doesn't mean it is a higher resolution. It's how many dots are on a line one inch long.
Now, if you take that 8.5 PDF at 300 DPI and print it on 36x48 the resolution will get lower because you have the same number of dots but more inches. Conversly, a 36x48 PDF at 300 DPI printed on 8.5x11 will have a higher resolution.
CAD Tech
lamarn
« Reply #6 on: December 11, 2015, 08:55:06 AM »
Forget it Rob!  :devilsidesmile:
Rob...
« Reply #7 on: December 11, 2015, 08:56:43 AM »
Huh? You don't agree with the definition?
CAD Tech
lamarn
« Reply #8 on: December 11, 2015, 09:39:14 AM »
One more try then.
If you scale a image with the same dpi what do you get?
Do you have a binoculars at home ?
Rob...
« Reply #9 on: December 11, 2015, 09:46:15 AM »
Please reread my post.
One more try then.
Try what? Redefine resolution?
A different resolution. That is what I said. The question is about generating PDFs not printing an existing one. A larger sheet generated at the same DPI is going to have more dots, not a higher resolution. It's a ratio thing not an absolute value.
CAD Tech
lamarn
« Reply #10 on: December 11, 2015, 09:50:55 AM »
Zz z :uglystupid2:
You really amaze me
Rob...
« Reply #11 on: December 11, 2015, 09:53:53 AM »
So, you agree?
You're not saying anything to refute my statements.
CAD Tech
