Author Topic: Show Palette in specific size on start up  (Read 8117 times)
Tharwat
  • Hypersensitive
« on: December 10, 2015, 03:10:34 AM »
I created a simple palette and added the codes to resize the palette at start up and it works in my laptop at home nicely but it doesn't work in my computer at the office.
Is there any System variable or so that controls the palette's size or re-sizing from machine to another ?
Thank you.
Re: Show Palette in specific size on start up
« Reply #1 on: December 10, 2015, 03:57:52 AM »
I haven't played for a while, BUT,
you know what I'm going to ask.
Can you post a .ODCL and a .LSP with the minimum content to show the issue.
  added: If Owen needs to debug this it will save you time later.
A snapshot of the result in each case may help.
Is this for AutoCAD or BricsCAD
I have a recollection that the last used size may be saved in the registry ... but that may be a scrambled recollection.
Resizing is another issue. Is the palette docked? ... That was an issue at one stage ( again, old and possibly scrambled recollection )
Added:
Have you considered posting at the OpenDCL forum ?  You may be able to attract a broader base of regular users.
« Last Edit: December 10, 2015, 09:45:07 AM by Kerry »
Tharwat
  • Hypersensitive
« Reply #2 on: December 10, 2015, 05:10:26 AM »
I knew that you'd do and that's why I said it is simple palette.  :wink:
added: It Owen needs to debug this it will save you time later.
Sorry , that is not clear enough to me.
added:
Yes I have , but I am a frequent user to theSwamp and wanted to check it out here first.
I am not using BricsCAD at all.
  1. (command "OPENDCL")
  2. (defun c:test (/)
  3.   (dcl-project-load "AutoSleeve")
  4.   (dcl-form-show autosleeve/form1)
  5.   (princ)
  6. )
  7. (defun c:autosleeve/form1#oninitialize (/)
  8.   (dcl-Control-SetAllowResizing AutoSleeve/Form1 t)
  9.   (dcl-Form-Resize AutoSleeve/Form1 260. 425.)
  10.   (princ)
  11. )
  12.
Thank you.
Tharwat
  • Hypersensitive
« Reply #3 on: December 10, 2015, 06:13:46 AM »
What a work around on this problem or it might be considered a solution .
Changing the color of the palette to any color would solve it.  :2funny:
« Reply #4 on: December 10, 2015, 09:44:30 AM »
I meant that Owen Wengerd from OpenDCL would require a sample so he could look for problems.
« Reply #5 on: December 10, 2015, 11:03:50 AM »
Can you be more explicit about
.... but it doesn't work in my computer at the office.
I note that you are re-sizing to the asDesigned values.
Your design works out of the box for me
Tharwat
  • Hypersensitive
« Reply #6 on: December 10, 2015, 11:19:09 AM »
I mean , when I use the above posted codes in my laptop at home it works but when I use it at the office it doesn't change the size of the palette and it is starting expanded as in your snapshot ( expanded from bottom to top ).
Now after changing the color of the palette , the settings of the palette is enough to set the palette as per the settings without the needs of the above posted codes to re-size the palette on the fly ( on invoking/opening ).
Try to change the palette's color to any one you like , then just use the codes to load and show the palette without the codes to re-sizing on initializing.
Like this:
  1. (defun c:test (/)
  2.   (dcl-project-load "AutoSleeve")
  3.   (dcl-form-show autosleeve/form1)
  4.   (princ)
  5. )
