Author Topic: Form-show giv 2  (Read 6392 times)
cadplayer
Form-show giv 2
« on: December 08, 2015, 04:52:17 AM »
Hello!
What is happening, if I type (dcl_Form_Show diroTool_Main 0 0) I get 2 and does not show Dialog, that means the form-show process is canceled. But I didnīt press escape.
The same dialog shows normaly on annother maschine. How can I fix it?! Have I to do something in form-install ?
« Last Edit: December 08, 2015, 05:05:16 AM by cadplayer »
Re: Form-show giv 2
« Reply #1 on: December 08, 2015, 05:07:04 AM »
Without seeing .odcl and .lsp we'll be playing guessing games.
roy_043
  • BricsCAD 18
Re: Form-show giv 2
« Reply #2 on: December 08, 2015, 06:59:55 AM »
If the form is modeless the return value does not indicate that Escape has been pressed. Perhaps the dialog is being shown off-screen?
This may help:
http://www.opendcl.com/forum/index.php?topic=1625.msg8041#msg8041
cadplayer
Re: Form-show giv 2
« Reply #3 on: December 09, 2015, 01:49:08 AM »
These are results of maschine there Dialog displayed
Command: (command "_OPENDCL")
nil
Command: (dcl_Project_Load "h:\\Dropbox\\2014\\dcl\\DiroTool.odcl")
"diroTool"
Command: (dcl_Form_Show diroTool_Main)
30
The diffrent to maschine it doenīt work is:
2
And that is the problem, because it means Dialog is canceled
roy_043
  • BricsCAD 18
Re: Form-show giv 2
« Reply #4 on: December 09, 2015, 03:29:26 AM »
1+
Re: Form-show giv 2
« Reply #5 on: December 09, 2015, 03:46:32 AM »
Also ;
Acad Version           ?
Operating System   ?
OpenDcl build on each machine   ?
Is the OpenDCL on both machines tested, or the Runtime ?
Modeless or Modal ?
How many documents were open ?
"The answer to the ultimate question of life, the universe and everything is 42."
