Author Topic: wcmatch special character problems  (Read 2007 times)
GDF
« on: December 07, 2015, 02:10:18 PM »
doing:
(setq TXTX (cdr (assoc 1 (entget (entlast)))))
gets this string:
"7'-0" CLEAR HEAD HEIGHT, CLEARANCE AT TOP STAIR, LANDING @ 11'-3 7/8" AFF"
can't get this to work:
(wcmatch TXTX  "[ , ]")
Re: wcmatch special character problems
« Reply #1 on: December 07, 2015, 02:14:24 PM »
Maybe?
  1. (wcmatch txtx "*,*")
ribarm
  • Marko Ribar, architect
« Reply #2 on: December 07, 2015, 02:30:47 PM »
Command: (vl-string-search "," txtx)
23
Command: (vl-string-search "," txtx 24)
47
Command: (wcmatch txtx "*, *")
T
M.R. on Youtube
« Reply #3 on: December 07, 2015, 02:47:01 PM »
(wcmatch text "*`,*")
GDF
« Reply #4 on: December 07, 2015, 03:42:42 PM »
I thought I had tried all of the options.
Only have two "," in the text placed in the drawing from another routine.
This is an old clunky routine, but for now it works.
result:
from the original post above:
This code used twice in the main routine:
 (if (wcmatch TXTX "*`,*")(BTXit))
;;;Break text original by
;;;written: Andrzej GUMULA     agumula@transprojekt.com.pl
(defun BTXIT (/ ELEM ETYK CM OS OLDERR PTW PT10 TMP ODL OPIS TBOX ITEM)
  (defun XY (A) (list (car A) (cadr A))) ;end xy
  (defun DXF (A B) (cdr (assoc A B))) ;end dxf
  (defun STRIM (A)
    (while (member (substr A 1 1) (list " " "." ";" ","))
      (setq A (substr A 2))
    ) ;_ end of while
    A
  ) ;end strim
  (defun PRPT (A B)
    (if (not (assoc A ELEM))
      (setq ELEM (append ELEM (list (cons A B))))
    ) ;_ end of if
    ELEM
  ) ;end prpt
  (setvar "CMDECHO" 0)
  (setvar "OSMODE" 0)
  (setvar "UCSFOLLOW" 0)
  (command "_undo" "_be")
     (if (and (setq ELEM (entget (entlast)))
     (eq (DXF 0 ELEM) "TEXT")
      (progn (setq PTW (XY (trans (cdr (assoc 10 ELEM)) 1 0)))
     (command "_ucs" "_ob" (cdar ELEM))
     (setq PTW (trans PTW 0 1)
   OPIS (DXF 1 ELEM)
   ITEM 1
   TEMP 0.0
     (while (or (not (member (substr OPIS ITEM 1)
     (list ",")
(< TEMP (car PTW))
    ) ;_ end of or
       (setq TBOX (textbox (subst (cons 1 (substr OPIS 1 ITEM))
  (assoc 1 ELEM)
  ELEM
  ) ;_ end of textbox
     TEMP (- (caadr TBOX) (caar TBOX))
     ITEM (1+ ITEM)
     (entmod (subst (cons 1 (substr OPIS 1 (1- ITEM)))
    (cons 1 OPIS)
    ELEM
     (setq A (append A (list '(62 . 4))))
     (PRPT 62 256)
     (PRPT 6 "BYLAYER")
     (entmake
       (subst (cons 1 (STRIM (substr OPIS (1+ ITEM))))
      (cons 1 OPIS)
      ELEM
     (command "_move"
      (entlast)
      "0,0"
      (list 0 (- (* 1.4 (DXF 40 ELEM))))
    (command "_ucs" "_p")
  (command "_undo" "_e")
« Reply #5 on: December 07, 2015, 03:59:39 PM »
If you're looking for text with two commas, you could use a filter like so:
  1. (SSGET "_x" '((0 . "TEXT")(1 . "*`,*`,*")))
GDF
« Reply #6 on: December 07, 2015, 04:16:08 PM »
Sweet
