Author Topic: Pick two points and draw rectangular box  (Read 3871 times)
Coder
Re: Pick two points and draw rectangular box
« Reply #15 on: December 07, 2015, 03:51:33 AM »
Thank you so much.  :-)
« Reply #16 on: December 07, 2015, 04:04:33 AM »
Pleased I was able to help.
David Bethel
« Reply #17 on: December 07, 2015, 11:35:11 AM »
You may want to read  :   Congruence of triangles
https://en.wikipedia.org/wiki/Euclidean_geometry
SideSideSide SideAngleSide AngleSideAngle
All need 3 input values in order to replicate the triangle
-David
R12 Dos - A2K
« Reply #18 on: December 09, 2015, 06:40:20 PM »
-David
You're a sadist David :) ... that's a tough read for someone who is "Weak at Math"
