Author Topic: Is Nothing ...  (Read 6720 times)
Is Nothing ...
« on: December 02, 2015, 01:27:42 AM »
I'm compiling some old VB.net code and came across something I thought was interesting.
The code compiled, netloaded and ran fine , but Resharper's solution-Wide Analysis reports an error
at If rbXD Is Nothing = False Then
      xxxx.vb:29 'Is' expression operand must be reference or nullable type
The changes I made removed the error report.
Code - vb.net: [Select]
  1.                     'If btr.IsAnonymous = True Then       'out kdub
  2.                     If btr.IsAnonymous Then               'replaced kdub 2015.12.02
  3.                         Dim rbXD As ResultBuffer = btr.XData
  4.                         rbXD = btr.GetXDataForApplication("AcDbBlockRepBTag")
  5.
  6.                         'If rbXD Is Nothing = False Then  'out kdub
  7.                         If rbXD IsNot Nothing Then        'replaced kdub 2015.12.02
  8.
  9.                             For Each tv As TypedValue In rbXD
  10.                                  ' do mojo here
  11.
The original code would have been written several years ago.
I'm compiling for AC2016 Net Framework 4.6 with VS2015 addin ReSharper 10
Has anyone come across this before ?
« Last Edit: December 02, 2015, 01:48:42 AM by Kerry »
gile
  • Marseille, France
Re: Is Nothing ...
« Reply #1 on: December 02, 2015, 01:44:08 AM »
From MSDN > Visual Basic Reference > Nothing:
When checking whether a reference (or nullable value type) variable is null, do not use = Nothing or <> Nothing. Always use Is Nothing or IsNot Nothing.
And someones still think VB is simpler than C#...
Re: Is Nothing ...
« Reply #2 on: December 02, 2015, 01:51:52 AM »
It sure wasn't me :)
We have a wager here about who will be the first to poke fun at me for using VB.net.
gile
  • Marseille, France
Re: Is Nothing ...
« Reply #3 on: December 02, 2015, 01:54:34 AM »
As VB also stands for VerBose, we should have to write:
  1. If myOwnVariable IsNot Nothing = True Then
  2.     Return True
  3. End If
:evil:
Jeff H
Re: Is Nothing ...
« Reply #4 on: December 02, 2015, 08:59:10 AM »
Not me I do not consider VB to be code
tetrahidrocannabinol
Re: Is Nothing ...
« Reply #5 on: December 02, 2015, 03:43:41 PM »
  2.     Return True
  3. End If
:evil:
I guess that is a joke, Where do you say that you have read/learned that?
In any case, VB and VB.NET are different things.
Re: Is Nothing ...
« Reply #6 on: December 02, 2015, 08:08:01 PM »
Yes it was, I guess he made it up, yes they are different.
I thought it was funny ... painful, but funny.
tetrahidrocannabinol,
after answering 100 posts here and demonstrating that you know what you're talking about you're allowed to make fun of the languages people use to program with.
gile
  • Marseille, France
Re: Is Nothing ...
« Reply #7 on: December 03, 2015, 03:37:18 AM »
thc,
Yes I was joking.
My apologies if it wasn't explicit, English isn't my native language.
I have not learn this, but I've read similar redundant expressions and not always written in a language of VB family (VB, VBA, VB.NET).
I know VB and VB .NET aren't the same, but I was just joking about language, and, as far as I know VB.NET succeeds to VB and keeps most of its (crappy <- joking?) features.
Anyway, I think any language (or language family) owns its 'culture' and the used language influences the way we are coding, this is essentially due to reproducing the read examples while learning.
For example the use of the prefix 'My' in naming variables is characteristic of the VB(A | .NET) culture, as is a tendency to verbosity.
By my side, I tend to be more verbose when I use C# than when I use LISP or F# (I don't use any language from VB family).
Kerry,
A little ConsoleApplication to illustrate Nothing (strange) behavior:
  1.     Sub Main()
  2.         Dim i As Integer = 0
  3.         Dim j As Integer = Nothing
  4.         Dim s As String = Nothing
  5.         Dim e As String = ""
  6.         Console.WriteLine("i = Nothing  => {0}", i = Nothing)
  7.         Console.WriteLine("i = 0        => {0}", i = 0)
  8.         Console.WriteLine("j = Nothing  => {0}", i = Nothing)
  9.         Console.WriteLine("j = 0        => {0}", i = 0)
  10.         Console.WriteLine("s = Nothing  => {0}", s = Nothing)
  11.         Console.WriteLine("s Is Nothing => {0}", s Is Nothing)
  12.         Console.WriteLine("s = """"       => {0}", s = "")
  13.         Console.WriteLine("e = Nothing  => {0}", s = Nothing)
  14.         Console.WriteLine("e Is Nothing => {0}", s Is Nothing)
  15.         Console.WriteLine("e = """"       => {0}", s = "")
  16.     End Sub
Output:
i = Nothing  => True
i = 0        => True
j = Nothing  => True
j = 0        => True
s = Nothing  => True
s Is Nothing => True
s = ""       => True
e = Nothing  => True
e Is Nothing => True
e = ""       => True
  1. i Is Nothing
throws a compilation time error because i is a non nullable value type.
« Last Edit: December 03, 2015, 04:37:32 PM by gile »
Re: Is Nothing ...
« Reply #8 on: December 03, 2015, 05:05:39 PM »
I think that is a good observation gile.
and Thanks for the ConsoleApplication printout.
Keith Brown
Re: Is Nothing ...
« Reply #9 on: December 04, 2015, 12:18:14 PM »
I won't name names but at an Autodesk University class taught by an Autodesk API member I saw this code.
  1. If DoSomeMethod(Variable) = True Then
  2.
  3.     DoSomething
  4.
  5. End If
While technically not incorrect God does kill a kitten every time someone does this.
** edited code to equal true instead of false **
« Last Edit: December 05, 2015, 01:14:57 AM by Keith Brown »
Re: Is Nothing ...
« Reply #10 on: December 05, 2015, 12:14:20 AM »
  1. If DoSomeMethod(Variable) = False Then
  2.
  3.     DoSomething
  4.
  5. End If
Are you suggesting that code should only do something if a method returns True .. because if you are, I must admit that I have single handedly caused the death of tens of thousands of poor kittens.
On second thought, maybe the method needs to be refactored to return True so you can only do stuff when it is True ...
Hell, I dunno ... I write code that makes sense to me when I write it, later on I shake my head in wonder .. as in I wonder what the hell I was thinking when I wrote that.
I prefer something like this
  1. If DoSomeMethod(Variable) Then
  2.     DoSomething
  3. End If
or maybe
  1. DoSomeMethod(InVariable OutVariable)
  2. If OutVariable = Somevalue Then
  3.     DoSomething
  4. End If
What I don't like is this
  1. Function MyFunction() As Boolean
  2.     If DoSomeMethod() = True
  3.         Return True
  4.     Else
  5.         Return False
  6.     End If
  7. End Function
  8. 'or this
  9. Function MyFunction(ReferenceObject) As Boolean
  10.     Dim TestObject As Object
  11.     For X As Integer = 0 to 9
  12.         Variable = GetSomeObjectByMethod(X)
  13.         If TestObject Equals ReferenceObject
  14.             Return True
  15.         End If
  16.     Next X
  17.     Return False
  18. End Function
Keith Brown
Re: Is Nothing ...
« Reply #11 on: December 05, 2015, 01:16:17 AM »
Oops.  Edited my post as the conditional check should have been equal to True.   It was a long week and just got home from AU.
So I was trying to suggest you only need this
  2.     DoSomething
  3. End If
« Last Edit: December 05, 2015, 01:20:19 AM by Keith Brown »
Re: Is Nothing ...
« Reply #12 on: December 05, 2015, 01:36:53 AM »
Those last couple of snippets remind me :
I'm not really picking on VB, but is it the only language set that used the same symbol for the assignment operator and the equality test operator ??
Re: Is Nothing ...
« Reply #13 on: December 05, 2015, 04:05:03 PM »
I honestly don't know ... but I cannot think of another language that does.
CADbloke
  • Crash Test Dummy
Re: Is Nothing ...
« Reply #14 on: December 06, 2015, 05:38:59 PM »
It's not really a language but Excel formulas use a single = for both assignment and equality. Of course, Excel is no stranger to VB(A). Also, Excel allows such abominations as ="string " & "more string "& (100-3)*7 so a single equals sign is not its most offensive behaviour.
