Author Topic: Mechanical Equipment Family - View Range?  (Read 9884 times)
Rob...
Re: Mechanical Equipment Family - View Range?
« Reply #15 on: November 30, 2015, 12:19:12 PM »
I still think it's a simple matter of view discipline.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-DocumentPresent/files/GUID-5D8831F6-6F15-4BF3-ACEB-06FBC14A5491-htm.html
I don't see that as an option. Maybe you misunderstand. Everything shows when inserted into a model. It's the floor plan view within the family that doesn't show anything above 4.5'.
Properties box of view within family:
CAD Tech
Rob...
« Reply #16 on: November 30, 2015, 12:20:25 PM »
also, is the View Range for that view correct?
There is no view range!
Why don't you open up a mechanical equipment family before you post suggestions?
CAD Tech
« Reply #17 on: November 30, 2015, 12:24:26 PM »
The view range is not for the family...it's for the view(s)
Rob...
« Reply #18 on: November 30, 2015, 12:27:23 PM »
Please stop, reread, and test. The problem exists in the family. You are only making yourself look foolish.
CAD Tech
« Reply #19 on: November 30, 2015, 12:31:25 PM »
Then go change the Family's view range properties.
Rob...
« Reply #20 on: November 30, 2015, 12:33:01 PM »
You really need to stop for your own sake. There is not a view range in the family views.
CAD Tech
« Reply #21 on: November 30, 2015, 12:38:07 PM »
I dunno; it appears you are describing something similar to this issue:
http://www.revitforum.org/architecture-general-revit-questions/10600-adjust-view-range-family-document.html
Rob...
« Reply #22 on: November 30, 2015, 12:51:01 PM »
Okay, it seems as if you finally got lucky with reply #19 and I misspoke because I did not see your image.
Edit: Corrected post number.
« Last Edit: November 30, 2015, 01:16:32 PM by Rob... »
CAD Tech
« Reply #23 on: November 30, 2015, 12:57:45 PM »
Okay, it seems as if you finally got lucky with reply #9 and I misspoke because I did not see your image.
Or perhaps YOU got lucky with my post number nine (9)
John Kaul (Se7en)
« Reply #24 on: November 30, 2015, 01:11:08 PM »
`in the family'?! ...Ah! I missed that part. Sorry. Glad you guys got it figured out though--even with my wild goose chase comments-.
Rob...
« Reply #25 on: November 30, 2015, 01:15:31 PM »
Mr. Farrell had a lot more blind geese than you did.
CAD Tech
« Reply #26 on: November 30, 2015, 01:18:29 PM »
You're welcome, and have a nice day!
edit
removed miss-quote
« Last Edit: November 30, 2015, 07:11:20 PM by Kerry »
John Kaul (Se7en)
« Reply #27 on: November 30, 2015, 01:19:39 PM »
lmao
You guys crack me up.
Rob...
« Reply #28 on: November 30, 2015, 01:23:40 PM »
Don't put words into my mouth. You caused more aggravation with your stabs in the dark than relief of finding a solution. I gave you credit as due and you may see me as a leech, but do not quote me with stuff I didn't say.
CAD Tech
Rob...
« Reply #29 on: November 30, 2015, 01:27:37 PM »
Quote from: mjfarrell link
I too, find him increasingly funny.
I'd much rather you didn't even respond in any fashion to my questions. I don't want your kind of help.
CAD Tech
