Author Topic: AutoCAD Stuck while try to open a file  (Read 3385 times)
HasanCAD
« on: November 29, 2015, 01:49:44 AM »
While try to open a file AutoCAD stuck and not accept any command even save.
Jeff H
Re: AutoCAD Stuck while try to open a file
« Reply #1 on: November 29, 2015, 03:57:42 AM »
Have noticed newer version will get stuck, error out, etc.. more often due to xrefs without any notification.
The 2 things I have done
1. Open default drawing and LOGFILEON and/or might need to set LOGFILEMODE = 1 then open the drawing and look at log file to see where it got stuck.
2. Try to recovering or open and repair the xrefs used in the drawing.
HasanCAD
« Reply #2 on: November 29, 2015, 04:08:27 AM »
Whats path for log file?
This is log file
[ AutoCAD - Sun Nov 29 10:52:34 2015  ]----------------------------------------
LOGFILEON
Command: XR XREF
Command:
Command: *Cancel*
Command: *Cancel*
Command: _XATTACH
Command:
Command:
Command: _qsave
Command:
Command:
Command: _open
Jeff H
« Reply #3 on: November 29, 2015, 04:44:06 AM »
LOGFILEPATH
HasanCAD
« Reply #4 on: November 29, 2015, 08:17:49 AM »
LOGFILEPATH
I got the path from options / files
« Reply #5 on: November 29, 2015, 11:16:14 PM »
LOGFILEPATH
I'm sure Jeff meant for you to look at
Command: (getvar 'LOGFILEPATH)
"C:\\Users\\KDUB04\\appdata\\local\\autodesk\\autocad 2016\\r20.1\\enu\\"
or
http://help.autodesk.com/view/ACDLT/2016/ENU/?guid=GUID-0E2D4DF2-4C26-48AC-ACBC-819E3C46CE59
« Reply #6 on: November 29, 2015, 11:22:34 PM »
Has it happened since ??
One thing I have learnt ( the hard way) over the years ( applies to any application with volatile data).
Save often ... Particularly before doing something the has ANY chance of freezing the Application
HasanCAD
« Reply #7 on: November 30, 2015, 01:15:49 AM »
LOGFILEPATH
or
Yes that what I did
I found LOG file with file name, and copied all contains.
