Author Topic: Selection between 2 points but excluding any objects on the exact points.  (Read 7117 times)
Re: Selection between 2 points but excluding any objects on the exact points.
« Reply #15 on: November 30, 2015, 07:14:26 AM »
directly under the line of selection
do you mean behind,  or do you mean below ?
Unless excluded by the endpoint locations I'd expect behind or in front  would be selected, not below or above.
« Reply #16 on: November 30, 2015, 09:04:36 AM »
With the additional conditions & selection criteria that you mention, it may be easier to follow a variation of the 'Option 1' method I suggest earlier, for example:
  1. (defun ObjectIdentification ( pt1 pt2 fuz / ang app per rtn )
  2.           ang (angle pt1 pt2)
  3.           per (- ang (/ pi 2.0))
  4.           pt1 (polar pt1 ang fuz)
  5.           pt2 (polar pt2 ang (- fuz))
  6.     )
  7.     (setq rtn
  8.         (ssget "_CP"
  9.             (list
  10.                 (polar pt1 per fuz)
  11.                 (polar pt2 per fuz)
  12.                 (polar pt2 per (- fuz))
  13.                 (polar pt1 per (- fuz))
  14.             )
  15.         )
  16.     )
  17.     (vla-zoomprevious app)
  18.     rtn
  19. )
To test:
  1. (defun c:test ( / p q )
  2.     (if
  3.         (and
  4.             (setq p (getpoint "\n1st point: "))
  5.             (setq q (getpoint "\n2nd point: " p))
  6.         )
  7.         (sssetfirst nil (ObjectIdentification p q 1e-3))
  8.     )
  9. )
LSElite
« Reply #17 on: November 30, 2015, 05:31:58 PM »
Cheers LM, I will test it out tonight.
“A life spent making mistakes is not only more honorable, but more useful than a life spent doing nothing.”
― George Bernard Shaw
LSElite
« Reply #18 on: December 01, 2015, 06:21:37 AM »
It worked a treat, Cheers LM and cheers Kerry.
I learned alot over this post, and I got my problem solved  :-D
« Reply #19 on: December 01, 2015, 07:46:40 AM »
Excellent to hear LSElite - you're most welcome.  :-)
And of course, if you have any questions concerning the method used in the last code posted, feel free to ask.
LSElite
« Reply #20 on: December 01, 2015, 08:07:48 AM »
I was going to put it down to magic.
I think I understand though I am not certain.
It finds the internal points from the inital points.
It then zooms the screen on the internal points leaving the intial points off the screen.
It them does a selection from the initial points and skips the objects because they are off the screen?
Am I close?
« Reply #21 on: December 01, 2015, 12:24:41 PM »
Close -
The function is essentially retrieving a selection using the following crossing-polygon selection window (hence the "_CP" mode string), which is offset from the supplied endpoints by the given fuzz value, and has a width equal to the given fuzz value:
LSElite
« Reply #22 on: December 01, 2015, 05:25:48 PM »
Ahhh!, Of course!
Now I get it, that is really cool.
I could be wrong but could the zoom possibly cause issues?
because it uses the internal points instead of the supplied points and moves the perpendicular points off the screen?
I think it would be an easy fix if it is an issue, to simply move the zoom to the start of the function before pt1 and pt2 are changed.
« Reply #23 on: December 01, 2015, 05:54:03 PM »
Perhaps, but in reality since the fuzz value will be very small (~1e-3 or less), this shouldn't have too much effect.
LSElite
« Reply #24 on: December 02, 2015, 06:23:01 AM »
Okay so after close inspection this program still is not giving back 100% accurate output.
I need it to remove lines that are collinear with the line made by the selection.
ie, crosses between both points.
Any Ideas?
« Reply #25 on: December 02, 2015, 07:32:23 AM »
Iterate over the selection and remove those lines which do not intersect the selection line (use the inters function to test this).
LSElite
« Reply #26 on: December 02, 2015, 09:50:38 PM »
I was wrong again :(
I just need it to remove all objects on the initial points from the selection set.
I will keep playing around with my initial code but if anyone knows a better way of removing one selection set from another please let me know.
« Reply #27 on: December 02, 2015, 11:28:30 PM »
Have a play
  1.
  2.
  3. ;; Subtracts one selection set from another and returns their difference
  4. ;; ssMain - Selection set to Subtract from
  5. ;; ssSub  - Selection set to subtract
  6.
  7. (defun kdub:SSSubtract (ssMain ssSub / ssResult n s)
  8.   (setq n   -1
  9.         ssResult ssMain
  10.   )
  11.   (repeat (sslength ssSub)
  12.     (if (ssmemb (setq s (ssname ssSub (setq n (1+ n)))) ssResult)
  13.       (ssdel s ssResult)
  14.     )
  15.   )
  16.   ssResult
  17. )
  18.
Image added:
« Last Edit: December 02, 2015, 11:46:03 PM by Kerry »
LSElite
« Reply #28 on: December 03, 2015, 05:30:51 PM »
It worked perfectly.
Cheers Kerry, you are a life saver!
Here is the function if anyone wants it:
  1. (defun ObjectIdentification ( pt1 pt2 app / p1 p2 p3 p4 ang per fuz ss ss1 ss2)
  2.         ;; Subtracts one selection set from another and returns their difference
  3.         ;; ssMain - Selection set to Subtract from
  4.         ;; ssSub  - Selection set to subtract
  5.         (defun kdub:SSSubtract (ssMain ssSub / ssResult n s)
  6.                 (setq n -1 ssResult ssMain)
  7.                 (repeat (sslength ssSub)
  8.                         (if (ssmemb (setq s (ssname ssSub (setq n (1+ n)))) ssResult)
  9.                                 (ssdel s ssResult)
  10.                         )
  11.                 )
  12.         ssResult)
  13.
  14.         (vla-zoomwindow app (vlax-3D-point pt1) (vlax-3D-point pt2))
  15.         (setq   fuz             5
  16.                         ang     (angle pt1 pt2)
  17.                         per     (- ang (/ pi 2.0))
  18.                         pnt1    (polar pt1 ang fuz)
  19.                         pnt2    (polar pt2 ang (- fuz))
  20.                         ss              (ssget "_CP"
  21.                                                 (list   (polar pnt1 per fuz)
  22.        (polar pnt2 per fuz)
  23.        (polar pnt2 per (- fuz))
  24.        (polar pnt1 per (- fuz)))
  25.                                         )
  26.         )
  27.         (if ss
  28.                 (progn
  29.                         (setq   ang1    (/ pi 4)
  30.                                         p1              (polar pt1 (* ang1 3) fuz)
  31.                                         p2              (polar pt1 (* ang1 7) fuz)
  32.                                         p3              (polar pt2 (* ang1 3) fuz)
  33.                                         p4              (polar pt2 (* ang1 7) fuz)
  34.                         )
  35.                         (vla-zoomwindow app (vlax-3D-point p1) (vlax-3D-point p2))
  36.                         (setq ss1       (ssget "_C"     p1 p2))
  37.                         (vla-zoomwindow app (vlax-3D-point p3) (vlax-3D-point p4))
  38.                         (setq ss2       (ssget "_C"     p3 p4 ))
  39.
  40.                         (if (and ss ss1) (setq ss (kdub:SSSubtract ss ss1)))
  41.                         (if (and ss ss2) (setq ss (kdub:SSSubtract ss ss2)))
  42.                         (if ss (if (= (sslength ss) 0) (setq ss nil)))
  43.                 )
  44.         )
  45.         princ ss
  46. )
« Last Edit: December 03, 2015, 05:39:05 PM by LSElite »
