Not to explain why I want to do this, I have a question... Is it possible to reverse database order of stored entities inside DWG using Autolisp? I don't mind if SORTENTS dictionary changed accordingly and I am not searching for draworder inversion, but real database inversion... So I want something like when I use (setq e (ssname (ssget "_X") 0)) before lisp and then execute inversion that after routine this becomes true (equal e (ssname (ssget "_X") (1- (sslength (ssget "_X")))))... Of course DWG must have at least 2 visible entities in any space - visible for (ssget "_X")...
I don't want to use commands like COPYCLIP-COPYBASE with following PASTECLIP and to remake database, I just want to preserve enames like they are, but inverse order they are stored inside DWG...
Thanks for any help and opinion...
M.R.
