Hello!
I need some guys some can test this method
(defun c:xx()
(setq curve-obj (vlax-ename->vla-object (car (entsel "\m Select Polyline!"))))
(while (setq p (vlax-curve-getPointAtDist curve-obj (getdist "\n Enter a distance: ")))
(command-s "_point" p)
My problem is: the method works wrong in my AutoCAD Civil3d 2016 SP1.0 installation
After run command: xx
Select a Polyline and than give some distance values
it should set points exactly after distance value along the Polyline.
In my case it don΄t do that. It sets all points on startpoint from Polyline and random to the endpoint from Polyline.
Have somebody the same result, please give me a call.
