For example, I want to see in the official documentation additionally such info (for AutoCAD .NET API):
1. Working with the styles: text styles, table styles, dimension styles, etc (the EACH option of them what I see in their dialog windows). I spent a lot of time to know how to work with
some of these options
in the AutoCAD 2009 in the past (some of the problems are not exist in the newer AutoCAD versions).
2. Detailed info about the check standards (I read
this but this has errors and is not enaugh for me). Also I read some info in the ObjectARX SDK 2010, but it was for C++ instead of .NET and has not the expanded code samples.
3. Unit testing of the managed\unmanaged plagins of AutoCAD. By Autodesk I saw
this only.
4. Creating the definitions of the dynamic and parametric blocks (if this is possible).
5. Known API bugs and the workarounds.
6. The code samples of working with DXF through .NET API. Something I see for VB6 in the documentation, but current information is not enough (for me).
7. Examples of the mistakes which are made by developers most often (when they use AutoCAD .NET API). Sometimes it may be interesting not only for beginners.
Some of these themes I know decissions, but I didn't see the necessary info in the documentation when I was searching it in the past.
