Author Topic: .NET with VS2013  (Read 2445 times)
MSTG007
.NET with VS2013
« on: November 23, 2015, 09:50:00 AM »
I know there is information about this on the board somewhere. Hopefully this is any easy (re-direction). Is there a youtube video or step by step tutorial showing how to setup a basic project. I can usually find all the code, but as for referencing it and add all the other files to support the code, I get lost at.
Thanks for your help.
Civil3D 2020
Keith Brown
Re: .NET with VS2013
« Reply #1 on: November 23, 2015, 09:53:29 AM »
Here are a couple links to get you started.
http://usa.autodesk.com/adsk/servlet/index?id=18162650&siteID=123112
http://through-the-interface.typepad.com/through_the_interface/2006/07/getting_started.html
If you already have VS2013 installed then you can skip any steps related to installing it.
MSTG007
« Reply #2 on: November 23, 2015, 10:07:17 AM »
Thank you!
Civil3D 2020
ChrisCarlson
« Reply #3 on: November 23, 2015, 10:25:48 AM »
Sign up for this...
https://www.visualstudio.com/products/visual-studio-dev-essentials-vs
And max out the 6 month trial of Pluralsight
