Author Topic: Simply writing an array to an excel file  (Read 2590 times)
ekoneo
« on: November 21, 2015, 10:43:18 AM »
Hi all,
I have a class page including an array and I have a form including a button. When I pres the button in the form an excel file ll be created and the array ll write in this excel file. I downloaded Excel Library.
Anobody can help me with basic sample?
Keith Brown
Re: Simply writing an array to an excel file
« Reply #1 on: November 21, 2015, 04:33:13 PM »
Check out the last no below and once you have some code posted we can look at then we can help you better.
http://www.theswamp.org/index.php?topic=31867.0
ekoneo
« Reply #2 on: November 23, 2015, 04:55:57 AM »
Thanks Keith,
My simple work is atached to this message.
My class sheet's code is:
using System;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.IO;
using System.Windows.Forms;
using Autodesk.Civil.ApplicationServices;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.Civil.DatabaseServices;
using Autodesk.Civil.Settings;
using Autodesk.Civil.Runtime;
using Microsoft.Office.Interop.Excel;
namespace ClassLibrary9
    public class Class1
        public class Commands
            [CommandMethod("WriteToExcel")]
            public void Test()
                String myString = "E,X,E,R,C,I,S,E";
                Array myArray = myString.Split();
                System.Windows.Forms.Application.EnableVisualStyles();
                System.Windows.Forms.Application.Run(new Form1());
Form1's code is:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            //Write function to writing myArray to an excel file.
