Author Topic: Something new for me.  (Read 3364 times)
« on: November 25, 2015, 12:15:41 PM »
I came across this code tonight and it has me stumped
Code - C#: [Select]
  1.
  2.             Editor ed = default(Editor);
  3.             ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
  4.
  5.             PromptPointResult ppr1 = default(PromptPointResult);
  6.             ppr1 = ed.GetPoint(new PromptPointOptions("Select start point"));
  7.
  8.             if (ppr1.Status != PromptStatus.OK) {return;}
  9.
  10.             PromptPointResult ppr2 = default(PromptPointResult);
  11.             ppr2 = ed.GetPoint(new PromptPointOptions("Select end point"));
  12.             if (ppr2.Status != PromptStatus.OK) {
  13.                 return;
  14.             }
  15.
The source is
http://adndevblog.typepad.com/autocad/2015/11/mleader-text-that-reflects-mleaderstyle-settings.html
The code compiles and executes after netloading.
My query is regarding the use of the default keyword.
My help file associates it's use with generics where the type is unknown.
https://msdn.microsoft.com/EN-US/library/xwth0h0d(v=VS.140,d=hv.2).aspx
It's very late for me and I'm a little brain dead but I don't understand why the keyword is used.
Can anyone venture an opinion ??
Regards,
added:
I probably should ask Balaji :)
« Last Edit: November 25, 2015, 12:23:56 PM by Kerry »
Keith Brown
Re: Something new for me.
« Reply #1 on: November 25, 2015, 12:26:11 PM »
My thought is that it initializes each variable to its default value.  Used in case you do not know its default value.  In the context that it is being used, I do not belive that it is required.  c# will automatically set the variable to its default value in its constructors.
« Reply #2 on: November 25, 2015, 12:32:56 PM »
Hi Keith,
I stepped through in the debugger and the values were null until initialised on the following line ; so it serves no 'obvious/demonstrable' purpose.
My initial thoughts were the same as yours ... but it's been nagging at me .
« Reply #3 on: November 25, 2015, 12:44:07 PM »
I posted a comment for Balaji ... perhaps we'll know tomorrow.
for a giggle and with respect
« Last Edit: November 25, 2015, 12:57:37 PM by Kerry »
MickD
« Reply #4 on: November 25, 2015, 03:43:42 PM »
Given what was said in the help doc's it seems like a reasonable way to avoid using null as an initialiser which can only be a good thing in avoid null ref exceptions. Thanks for bringing it up :)
In the case of the Editor declaration above though, it is just wasted keystrokes and I'm surprised it compiles, perhaps it's optimised away by the compiler given the 'default' hint?
- John Carmack
- J.R.R. Tolkien
Keith Brown
« Reply #5 on: November 25, 2015, 04:07:44 PM »
If the variable is not initialized in the constructor, and it is a reference type it will be set to null anyway.  At least that is my understanding of how it works.  A reference type has a default value of null.  Correct?
MickD
« Reply #6 on: November 25, 2015, 04:24:50 PM »
Right you are Keith, my bad, I didn't grok it on first read through.
I was hoping it was .net heading in a direction to eliminate null (like in F#) although they would most likely have to implement the 'Option' type as an alternative which is much safer to use and check.
The example in the doc's shows one of the very few places it would be useful (inside a generic list), elsewhere there is no real reason to use it given the context you are working with as far as I can see.
- John Carmack
- J.R.R. Tolkien
« Reply #7 on: November 25, 2015, 09:09:23 PM »
A web search found a few usages of  default(PromptPointResult)
Most were by Oleg ( fixo ) during the last 2 1/2 years.
« Reply #8 on: November 26, 2015, 02:12:49 AM »
From the Author :
Balaji has replied to your comment:
Hi Kerry,
I had implemented the code in this blog post initially in VB.Net and later used an online converter to do the C# conversion for the sake of creating this blog post. The converter had introduced this and i did not notice it. Sorry, I do not know what that means. But, the C# version did build and run ok in AutoCAD.
Please do let me know if you have any information on it.
This is the converter that i had used for my VB.Net to C# conversion :
converter.telerik.com
Balaji
View the post and comment: http://adndevblog.typepad.com/autocad/2015/11/mleader-text-that-reflects-mleaderstyle-settings.html?cid=6a0167607c2431970b01b8d17b453d970c#comment-6a0167607c2431970b01b8d17b453d970c
added:
In light of this, it's possible that Oleg translated his usage from VB.net with the same translator.
huiz
  • Certified Prof C3D
« Reply #9 on: November 26, 2015, 03:17:01 AM »
The most common usage is in a Generic class, not when you create a new object form a known type.
public T Foo<T>() {
 return default(T);
huiz
« Reply #10 on: November 26, 2015, 03:19:14 AM »
Probably converted from VB.NET where you can use
  Dim variable As T = Nothing
« Reply #11 on: November 26, 2015, 03:19:41 AM »
public T Foo<T>() {
 return default(T);
Yes.
« Last Edit: November 26, 2015, 03:24:36 AM by Kerry »
« Reply #12 on: November 26, 2015, 03:23:57 AM »
I can't imagine that being the case. I doubt the original author would use generics for something like this ... it is VERY type specific.
Perhaps Balaji will post the VB.net code here if he happens to visit.
