Author Topic: Xref Project - plotting  (Read 9351 times)
Fabricio28
Re: Xref Project - plotting
« Reply #30 on: November 19, 2015, 01:45:32 PM »
-layer
n
XREF1
Select the xref
go to properties and  change the layer the object (xref) is on to XREF1 layer you just created
Wow
 :-D :-D :-D :-D :-D :-D :-D :-D
Kudos for you my friend.
When I went to properties the layer selected was (-VIEWPORT) and that layer I put not plotting.
I didn't know that.  :-o
Thank everyone for the help. I really appreciated all helps
Thank you guys
You will discover there are other good reasons to keep each XREF on it's own unique layer as well...
saves time unloading and re-loading them
overall layer control is improved - easier filtering
Thank you for the tip!  :-D
I've Learnt so much with you guys.
