Author Topic: Xref Project - plotting  (Read 9334 times)
Fabricio28
Re: Xref Project - plotting
« Reply #15 on: November 18, 2015, 09:05:46 AM »
I opened xref, blind the project and explode.
Now it is Fine, I can plot.  :-D
« Reply #16 on: November 18, 2015, 09:08:05 AM »
ok, then it is either
layers set to NOT PLOT or
Pens set to 255 (white) so they are plotting you just can not see them
check pen table against objects layer, color, linetype settings...
Also try create a NEW layer, use a color that you know is plotting and assign to new layer,
move the NON plotting objects onto that layer, edit civil object style also so that they are also using new layer
« Reply #17 on: November 18, 2015, 09:09:10 AM »
that should be the LAST thing anyone would want or need to do...
also it doesn't help you solve the underlying problem for future reference
Fabricio28
« Reply #18 on: November 18, 2015, 09:14:50 AM »
I was hurry to plot the project. So I rename it before explode.  :-D
tedg
« Reply #19 on: November 18, 2015, 04:25:28 PM »
two things...
one are there any 'unreconciled layers' ??  If yes fix them
try using another pen table...
Do the items that do not plot show up in the file before plotting?
Is plot paperspace last checked?
If you plot from Model Space do they plot?
Hi mjfarrel,
There aren't unreconciled layers.
I've change the pen table
The item that don't plot isn't show up.
Yes, paperspace last check
I'm trying to plot from model space and is the same layout space.
If the xref bases are ok, you may consider setting visretain to 0, then reloading the xrefs, (and then setting visretain back to 1) and see if that works.
This would put the layer states back to what is in the xref files and not any over-ridden layer states, or ones checked off to no plot.
Just a thought
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Rob...
« Reply #20 on: November 18, 2015, 04:47:57 PM »
More evidence of it being a layer issue.
What layer is that XREF inserted on?
CAD Tech
Fabricio28
« Reply #21 on: November 19, 2015, 11:24:06 AM »
Guys,
Good news I think...
all xref layer isn't plotting.
I don't know why.
two things...
Hi mjfarrel,
Just a thought
Hi tedg
I've detached and reload the file. I set visretain to 0 and 1.
I did everything you said and isn't working too.
« Reply #22 on: November 19, 2015, 12:10:32 PM »
again...make a NEW layer
move XREF to that layer
Fabricio28
« Reply #23 on: November 19, 2015, 12:36:52 PM »
Sorry but I didn't get what you mean by "make a new layer and move xref to that layer".
How Can I move xref to the layer?
« Reply #24 on: November 19, 2015, 12:38:24 PM »
-layer
n
XREF1
Select the xref
go to properties and  change the layer the object (xref) is on to XREF1 layer you just created
Fabricio28
« Reply #25 on: November 19, 2015, 12:56:44 PM »
-layer
n
XREF1
Select the xref
Wow
 :-D :-D :-D :-D :-D :-D :-D :-D
Kudos for you my friend.
When I went to properties the layer selected was (-VIEWPORT) and that layer I put not plotting.
I didn't know that.  :-o
Thank everyone for the help. I really appreciated all helps
Thank you guys
« Reply #26 on: November 19, 2015, 01:16:37 PM »
damn layers will get you every time. :D
Fabricio28
« Reply #27 on: November 19, 2015, 01:29:28 PM »
Yes, damn layers.
Rob...
« Reply #28 on: November 19, 2015, 01:31:25 PM »
You're welcome.
CAD Tech
« Reply #29 on: November 19, 2015, 01:35:59 PM »
-layer
n
XREF1
Select the xref
Wow
Thank you guys
You will discover there are other good reasons to keep each XREF on it's own unique layer as well...
saves time unloading and re-loading them
overall layer control is improved - easier filtering
