Author Topic: CAD drawings in Word documents  (Read 2926 times)
GPeyton
« on: November 17, 2015, 04:25:19 PM »
Is there a way to insert CAD drawings into a word document, lets say as a .wmf file. Create a link between the two, so if the CAD drawing changes it will automatically update the word document? The inserted drawing does not have to be a .wmf file, I have heard that is the best file format for inserting CAD files into Word. Any help will be appreciated. Thanks
Re: CAD drawings in Word documents
« Reply #1 on: November 17, 2015, 05:54:07 PM »
yes....copy and paste special I believe is all that is needed
« Reply #2 on: November 18, 2015, 12:09:42 AM »
What I do is plot preview in ACAD , use the Windows Snipper to copy to clip board.
The just paste to Word as if it were text & the image is sized to fit.
Windows 10 & MS Word 2007
You can snip from a PDF too & just past to Word.
cadtag
« Reply #3 on: November 19, 2015, 07:46:31 AM »
There's also BetterWMF.  I've not needed it in years, but IIRC it worked quite well.
« Reply #4 on: November 19, 2015, 07:49:03 AM »
That would be cool but I don't think it can be done.
dtkell
« Reply #5 on: November 19, 2015, 02:22:58 PM »
I've never used it, but Word 2013 has "Insert" "Object" and for "Create New" includes "AutoCAD Drawing" as a choice. I can't remember which version of Word started this, but I know it's been there for a while now.
It has option to insert from file, so if you can create drawing from new, it should insert drawing from file.
Whether or not it updates (like an xref or not), I do not know.
Experiment and explore!
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
« Reply #6 on: November 19, 2015, 02:51:13 PM »
Wow, cool. I can not get the object in the Word document to update though. You can even drag-n-drop a .dwg into Word.
dtkell
« Reply #7 on: November 19, 2015, 02:55:50 PM »
I did a quick play with it.
It seems the drawing exists within the word doc.
If you dbl click, it opens in acad. Edit it, save it and that is what you see in the word doc.
If you edit the original dwg, it has no effect on the doc dwg.
Matt__W
  • I like my water diluted.
« Reply #8 on: November 19, 2015, 02:57:39 PM »
I've always printed to PNG format and inserted the image file.
Autodesk Expert Elite
