Author Topic: Simulate click on toolbar  (Read 11491 times)
roy_043
  • BricsCAD 18
Re: Simulate click on toolbar
« Reply #30 on: January 18, 2017, 07:31:43 AM »
I have updated the code again. See here.
The function c:Osnap-FormToggle has been renamed to c:Osnaps-FormToggle.
This function only toggles the display of the form.
There is a new function c:Osnaps-Toggle.
This function toggles the osnaps (the 16384 bit) and changes the display of the form to match.
A keyboard shortcut should work with this as the command:
^P'Osnaps-Toggle^P
« Last Edit: January 18, 2017, 07:41:01 AM by roy_043 »
lamarn
« Reply #31 on: January 18, 2017, 05:34:19 PM »
Nice work Roy.. Great further improvement! Will make it more efficient en user friendly.
I decided to leave the F3 button unchanged because this these OpenDCL function don't fully work transparent.
So, i was thinking, this F4 button can be a great target since i never use with 3Dsnaps.
Here is how F-button can be adressed... follwing..
http://forums.autodesk.com/t5/autocad-2010-2011-2012/function-keys-customization/td-p/3045206
attached also the idea of pressing F3, F4
I Like it!
« Last Edit: January 18, 2017, 05:55:42 PM by lamarn »
roy_043
  • BricsCAD 18
« Reply #32 on: January 19, 2017, 03:36:11 AM »
... because this these OpenDCL function don't fully work transparent...
For the functions to work transparently you have to prefix the macro command with a single quote. It seems you have forgotten to do so. See the suggestion in my previous post. In BricsCAD c:Osnaps-Toggle and c:Osnaps-FormToggle can be used transparently.
Edit:
Mind you there is an issue (in BricsCAD 16 at least) when trying to use keyboard shortcuts if DYNMODE is on.
« Last Edit: January 19, 2017, 06:49:18 AM by roy_043 »
lamarn
« Reply #33 on: January 19, 2017, 03:41:03 PM »
Prolongated it to F3.
roy_043
  • BricsCAD 18
« Reply #34 on: January 19, 2017, 04:22:18 PM »
@Hans:
Do you also experience a problem with the transparent use of the command if you type:
'Osnaps-Toggle?
lamarn
« Reply #35 on: January 19, 2017, 06:00:42 PM »
No. I do some more testing
Will report if i've had any strange behaviour..
https://youtu.be/g5v36dmHStY
« Last Edit: January 19, 2017, 06:05:04 PM by lamarn »
Hugo
« Reply #36 on: January 20, 2017, 12:19:18 AM »
Wanted this also testing runs unfortunately OpenDCL on Autocad 2017 not.   :-( :-(
Wollte das auch Testen leider läuft OpenDCL auf Autocad 2017 nicht.
lamarn
« Reply #37 on: January 20, 2017, 03:07:53 AM »
Hi Hugo
What version did you install? Check their website /forum for 2017..
It runs on my laptop.
« Last Edit: January 20, 2017, 03:16:02 AM by lamarn »
Hugo
« Reply #38 on: January 20, 2017, 04:36:47 AM »
Autocad 2017 21.0s
How is the OpenDCL loaded with you?
Autocad 2017 21.0s
Wie wird bei dir das OpenDCL geladen ?
roy_043
  • BricsCAD 18
« Reply #39 on: January 20, 2017, 06:05:28 AM »
Autocad 2017 21.0s
Autocad 2017 21.0s
The program will load ODCL, but you have to have the correct ODCL version installed. And ODCL must be installed after AutoCAD.
lamarn
« Reply #40 on: January 20, 2017, 06:12:04 PM »
Autocad 2017 21.0s
Autocad 2017 21.0s
Like .dcl the .odcl files needs to be in the support path. The rest is the same, load the lisp (on activation)
lamarn
« Reply #41 on: December 06, 2018, 09:56:17 AM »
I'm picking up this old story about the osnap function.
What i really would like is to isolate the osnapz toggle function, written without opendcl code.
Meaning a reactor controls the grid in conjuction with the osnapz setting.
That would be a great function for wider use.
I isolates some code to start.  But i am not experienced enough to get this to work propertly.  :crazy2:
Maybe someone can help me with this.
Thanks!
(defun Osnapz-OnLoad () ; based on the work of Roy
    ;; Remove existing reactors:
    (mapcar '(lambda (rea)
                 (if (= "OSNAPZ" (vlr-data rea))
                     (vlr-remove rea)
            (apply 'append (mapcar 'cdr (vlr-reactors)))
    ;; Create new reactors:
    (vlr-sysvar-reactor
        "OSNAPZ"
        '((:vlr-sysvarchanged . Osnaps-CallBackSysvarChanged)
          (:vlr-sysvarwillchange . Osnaps-CallBackSysvarWillChange)
    (vlr-docmanager-reactor
        "OSNAPZ"
        '((:vlr-documentbecamecurrent . Osnaps-CallBackDocumentBecameCurrent)
          (:vlr-documenttobedeactivated . Osnaps-CallBackDocumentToBeDeactivated)
    (vlr-command-reactor
        "OSNAPZ"
        '((:vlr-commandcancelled . Osnaps-CallBackCommandCancelled)
          (:vlr-commandfailed . Osnaps-CallBackCommandCancelled)
          (:vlr-commandwillstart . Osnaps-CallBackCommandWillStart)
(defun Osnaps-CallBackSysvarChanged (rea lst)
    (cond ((= "OSNAPZ" (car lst)) (Osnaps-UpdateOsnapz nil)))
(defun Osnaps-CallBackDocumentBecameCurrent (rea lst)
(defun Osnaps-CallBackDocumentToBeDeactivated (rea lst)
  (Osnaps-UpdateOsnapz  T)
(defun Osnaps-UpdateOsnapz (disableP / btn)
  (if (setq btn Osnaps/Main/btnOsnapz)
      (disableP
        (dcl-Control-SetBackColor btn -16) ; here .., no opendcl codes ..
        (dcl-Control-SetForeColor btn -19) ; here .., no opendcl codes ..
      ((zerop (getvar 'osnapz))
        (dcl-Control-SetBackColor btn 0) ; here .., no opendcl codes ..
        (dcl-Control-SetForeColor btn 7) ; here .., no opendcl codes ..
      (T
        (dcl-Control-SetBackColor btn 7) ; here .., no opendcl codes ..
        (dcl-Control-SetForeColor btn 0) ; here .., no opendcl codes ..
; not working yet though
« Last Edit: December 06, 2018, 09:59:56 AM by lamarn »
lamarn
« Reply #42 on: December 10, 2018, 02:35:00 AM »
Aha. Just this one.
(defun c:Oz () (setvar 'gridmode (setvar 'osnapz (boole 6 (getvar 'osnapz) 1))) (princ))
