Your issue is the block has a scale other than 1 .. so you'd have to do the math (setvar 'pdsize (/ sizewanted blockscale)) to get whatever size you're trying to display. If you're just trying to display a circle at a fixed size, I'd define a circle within the block with a 1 unit diameter then control the size with the block scale.
