Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
shift+scroll or 3d PAN>>>can this be turned off?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: shift+scroll or 3d PAN>>>can this be turned off? (Read 3832 times)
bluepencil
Guest
on:
November 11, 2015, 07:12:59 AM »
Shift + Scroll initiates the 3d PAN...
but Shift + Right Click initiates the context menu which I always use... I am working on a MAC and when I am using the magic mouse... instead of a left click the mac reads the click as a scroll... which makes may drawing rotate on 3D... this frustrated me so I used the regular mouse with a scroll wheel...
Is there any system variable I can use to turn off the shift + scroll for 3d pan?
Thanks!
Logged
Rob...
King Gator
Take a little time to stop and smell the roses.
Re: shift+scroll or 3d PAN>>>can this be turned off?
Reply #1 on:
November 11, 2015, 07:22:12 AM »
Why is the MAC version using different terminology?
I think by 3d PAN you mean orbit.
I do not think you can turn off that behavior.
As to the magic mouse, I'm guessing that the setting would be in the mouse settings.
Logged
CAD Tech
ChrisCarlson
Guest
Reply #2 on:
November 11, 2015, 08:51:46 AM »
If MAC is similar to WIN, the option for "Transparent Orbit" and "Snap Menu" (I assume this is what you mean for context?) is under the CUI / Mouse Buttons / Shift+Click. Perhaps they are backwards?
I'm not sure what a shift and scroll is?
Logged
bluepencil
Guest
Reply #3 on:
November 11, 2015, 08:56:48 AM »
Shift[hold]+scroll mouse up and down it will rotate the UCS...
Shift[hold]+scroll button pressed and moved around it will go into 3d orbit and rotate on the z-axis...
i want to turn it off so because I only do 2D drawings most of the time...
Logged
ChrisCarlson
Guest
Reply #4 on:
November 11, 2015, 10:04:51 AM »
Navigate to the CUI settings I mentioned above and you should be able to delete/clear assignment them
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
