Author Topic: Need fresh eyes to ckeck this code  (Read 2610 times)
HasanCAD
« on: October 27, 2015, 09:33:36 AM »
This lisp select vport to get its scale put when paste in attribut not showing the field
  1. (defun c:CVS (/ enam elst objid fldexp enm2)
  2.         (vl-load-com)
  3.         (while (null (setq enam (car (nentsel "\nSelect Viewport: "))))
  4.                 (princ "Nothing Selected")
  5.         )
  6.   (cond ((and
  7.            (setq elst (entget enam))
  8.            (setq elst (member  (cdr (assoc 0 elst)) '("VIEWPORT")))
  9.            (setq objid (vla-get-ObjectId (vlax-ename->vla-object enam)))
  10.            (setq fldexp (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa objid) ".StandardScale2 \\f \" ""%en0" ">%"))
  11.
  12.            (setvar "cmdecho" 0)
  13.            (progn (If (and (not (= glay ""))
  14.                            (member glay (mapcar 'strcase (cons "MODEL" (layoutlist)))))
  15.                     (setvar 'Ctab glay)) T)
  16.            (setq enm2 (car (nentsel "\nSelect String: ")))
  17.            (setq enam (member  (cdr (assoc 0 (entget enm2))) '("ATTRIB" "TEXT" "MTEXT")))
  18.            (not (vla-put-textstring (vlax-ename->vla-object enm2) fldexp))
  19.            (setvar "cmdecho" 1)
  20.            (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport)
  21.            )
  22.          )
  23.         )
  24.     '(lambda (j) (if (null (eval (car j))) (princ (cadr j))
  25.                    ))
  26.     '((elst "\nSelected Entity is Not valid for Field value.")
  27.       (enm2 "\nNothing Selected")
  28.       (enam "\nSelected Entity is Not valid for Field value."))
  29.     )
  30.   (princ)
  31.   )
« Last Edit: October 27, 2015, 11:56:37 AM by HasanCAD »
Tharwat
  • Hypersensitive
Re: Need frish eyes to ckeck this code
« Reply #1 on: October 27, 2015, 09:51:52 AM »
Might be this one :
">%).StandardScale2 \\f \" "
HasanCAD
« Reply #2 on: October 27, 2015, 10:52:56 AM »
Might be this one :
Sorry for that but not working
Could you add the
  1. (setq fldexp (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa objid) ".StandardScale2 \\f \" ""%en0" ">%"))
« Reply #3 on: October 27, 2015, 11:34:23 AM »
Did not look to closely but this stood out:
  1. (defun c:cvs (/ elst enam enm2 fldexp objid)
  2.   (while (null (setq enam (car (nentsel "\nSelect Viewport: ")))) (princ "Nothing Selected"))
  3.   (cond ((and (setq elst (entget enam))
  4.               (setq elst (member (cdr (assoc 0 elst)) '("VIEWPORT")))
  5.               (setq objid (vla-get-objectid (vlax-ename->vla-object enam)))
  6.               ;; RJP - reformatted field code
  7.               (setq fldexp (strcat "%<\\AcObjProp Object(%<\\_ObjId "
  8.                                    (itoa objid)
  9.                                    " >%).StandardScale2 \\f \"%en0\">%"
  10.                            )
  11.               )
  12.               ;; RJP - why this code? .. 'glay' is always nil
  13. ;;;       (setvar "cmdecho" 0)
  14. ;;;       (progn
  15. ;;;         (if (and (not (= glay "")) (member glay (mapcar 'strcase (cons "MODEL" (layoutlist)))))
  16. ;;;           (setvar 'ctab glay)
  17. ;;;         )
  18. ;;;         t
  19. ;;;       )
  20.               (setq enm2 (car (nentsel "\nSelect String: ")))
  21.               (setq enam (member (cdr (assoc 0 (entget enm2))) '("ATTRIB" "TEXT" "MTEXT")))
  22.               (not (vla-put-textstring (vlax-ename->vla-object enm2) fldexp))
  23.               ;; RJP - why this code? .. no command calls in this code
  24. ;;;       (setvar "cmdecho" 1)
  25.               (vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport)
  26.          )
  27.         )
  28.   )
  29.   (vl-some '(lambda (j)
  30.               (if (null (eval (car j)))
  31.                 (princ (cadr j))
  32.               )
  33.             )
  34.            '((elst "\nSelected Entity is Not valid for Field value.")
  35.              (enm2 "\nNothing Selected")
  36.              (enam "\nSelected Entity is Not valid for Field value.")
  37.             )
  38.   )
  39.   (princ)
  40. )
Jeff H
« Reply #4 on: October 27, 2015, 11:49:00 AM »
What are frish eyes?
HasanCAD
« Reply #5 on: October 27, 2015, 11:57:36 AM »
  :uglystupid2:  :whistling:  fresh
Cathy
Re: Need fresh eyes to ckeck this code
« Reply #6 on: October 28, 2015, 02:55:02 PM »
Give this a try:
  1.            (setq fldexp (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa objid) ">%).StandardScale2 \\f \"%en0\">%"))
  2.
HasanCAD
« Reply #7 on: October 28, 2015, 03:42:56 PM »
Thanks ronjonp
Working perfect
HasanCAD
« Reply #8 on: October 28, 2015, 03:44:34 PM »
Give this a try:
  2.
Thanks Cathy
Working perfect
« Reply #9 on: October 28, 2015, 04:20:59 PM »
Thanks ronjonp
Working perfect
Glad to help :)
