Author Topic: Remote debugging of ARX  (Read 3616 times)
Andrey Bushman
« on: October 23, 2015, 07:37:18 AM »
I have the installed MS VS 2005-2015 on my local machine. My other remote machine has the installed AutoCAD 2009-2016. I always (many years) use the remote debugging when I write my .net plugins for AutoCADs. It is very convenient and works fine. Therefore I want to use remote debugging for ARX plugins too.
I created a "Hello World" ARX project for AutoCAD 2009 through the MS VS 2013 with V80 [MSVS 2005] tools using.
I compiled it and run in AutoCAD 2009 sucessfully.
But I can't launch the remote debugging. Attached files display my project settings and the message with a problem.
I don't understand which RDBG (2005 or 2013) I am to launch on the remote machine... I tried to use both, and also with\without the admin rights, but it didn't help me.
How can I get successfull remote debugging of ARX?
« Last Edit: October 23, 2015, 07:56:50 AM by Andrey Bushman »
Andrey Bushman
Re: Remote debugging of ARX
« Reply #1 on: October 23, 2015, 08:30:59 AM »
I found the reason of my problem. When I used the remote debugging for my .net applications, I didn't point the working directory and it worked fine. But for C++ projects I am to point it. If I set the working directory as C:\Program Files\Autodesk\AutoCAD 2009\ then the remote debugging works fine with C++ code too.
