Author Topic: Name Suggestions for Same Code, Multiple Projects, Multiple Builds  (Read 3653 times)
CADbloke
  • Crash Test Dummy
I am writing an app that automates sharing code between Visual Studio Projects. The code file exists only once, it is never copied or moved. New projects get a link to the existing code so they can use it too. If you change the code anywhere it changes everywhere. There is only one code, it just gets used in as many projects as you like. The app creates those new projects and automates the maintenance of their contents.
Refer to this (rather convoluted, sorry) thread for more details if you are unclear: http://www.theswamp.org/index.php?topic=50202.msg553839#msg553839 ...read downwards from there. Actually, that may not make it any clearer but there are pictures!
MickD
Re: Name Suggestions for Same Code, Multiple Projects, Multiple Builds
« Reply #1 on: October 23, 2015, 02:57:35 AM »
shared code?
I'm guessing in the other thread you discussed creating a library for said code but I have come across the same thing building for both Bricscad and AutoCAD and I just 'link' the files as you suggest.
- John Carmack
- J.R.R. Tolkien
Keith Brown
« Reply #2 on: October 23, 2015, 06:22:43 AM »
Code Linker?
I usually just add a common project to my assemblies and then just merge them when I build the project.  Smart Assembly automates this for me.
« Reply #3 on: October 23, 2015, 06:24:19 AM »
Priscilla ??
« Reply #4 on: October 23, 2015, 06:24:49 AM »
xLink
Keith Brown
« Reply #5 on: October 23, 2015, 06:27:14 AM »
xLink
I like this one.  I would maybe change it to vsLink to help spell out that it is for Visual Studio but a nice one anyway.
« Reply #6 on: October 23, 2015, 06:28:26 AM »
xLink = cross link
VSxLink
CADbloke
  • Crash Test Dummy
« Reply #7 on: October 23, 2015, 06:42:01 AM »
I like these suggestions. Keep it coming!
« Reply #8 on: October 23, 2015, 07:03:35 AM »
*them ...keep them coming.
LinX
And just because you VS people seem to love to partake in the iGame...
vsLinX
CADbloke
  • Crash Test Dummy
« Reply #9 on: October 23, 2015, 07:37:38 AM »
LinX
vsLinX
No  :p
« Reply #10 on: October 23, 2015, 07:56:05 AM »
maybe :)
CADbloke
  • Crash Test Dummy
« Reply #11 on: October 23, 2015, 08:05:48 AM »
maybe :)
Nup, needs an "i" for the kids, or perhaps some crazy backslash if you're gunna go full Linux on it.
« Reply #12 on: October 23, 2015, 08:21:08 AM »
maybe :)
I'm just saying: out of five people that replied to this thread two of them suggested adding some reference back to "visual studio".  Walks like a duck, talks...*QUACK!*
*chuckle* sudo make me a sandwich
Linux guys have the "gnu" thing. The slash is shared with Unix, BSD, and Linux people (and many others). Do not give those linux weirdos any more power to group in with the Unix camp anymore then they already have. Besides, you people just remember the MS camp is outnumbered by far (more OSs use `that slash thingie' then those that don't) and it wouldn't hurt if you ventured out of your MS sandbox once and a while; even if it was to wander over to the Linux park.
CADbloke
  • Crash Test Dummy
« Reply #13 on: October 24, 2015, 08:54:26 PM »
Ok, I'm sober now so I can make more sense of this.
...edit...hangover is wearing off so even more sense...
I agree it should mention Visual Studio and I think the references to "link" are also a good idea, since that's what it does.
xLink = cross link
VSxLink
Yeah, that.
Code Linker?
I think the obvious name there is probably the best one. VS Code Linker is where I'm gravitating towards ,everything else I have called is is a bit too obscure.
Smart Assembly would probably get the same result but this is cheaper. The reason I have gravitated towards linking in Visual Studio is so it is all right in front of me, I can read through the code in the IDE and see what it means in the context of the platform I'm working on at the time and figure out why I broke it and where. I don't have to learn anything new. I'm too old! Don't make me learn! (kidding but you get my gist).
I also wanted to be able to easily repurpose things I have already written so I can just drop it in and it will work. Mostly.
In any case, this is still evolving.  I hope to post the new one to Github in the next week or 2 with a wiki that makes at least a little sense.
« Last Edit: October 25, 2015, 07:30:19 PM by CADbloke »
CADbloke
  • Crash Test Dummy
« Reply #14 on: October 26, 2015, 10:19:43 PM »
In case you missed it in the other somewhat longer thread ...
I went with "Code Linker". You should have seen that renaming commit.  :tickedoff: . I should add more SEOness about it being for Visual Studio but it's late and I'm tired.
Published to Github.
...for those of you scrolling through looking for a link to the repo...
The Wiki is still a work in progress but it has some info about the GUI app and other things.
Please let me know what doesn't make sense. It's late, I'm tired but I just want to get it out to you. I will revisit it soon and edit my drivel.
