Author Topic: Revit - Export Exteriors to 3D  (Read 5560 times)
MSTG007
« on: October 20, 2015, 03:37:11 PM »
Just thinking out there. Is there a way to export just the outer face of the building and roof. Basically just the outside of the building (nothing inside) to a 3D Model? I was curious if I could do that, then import that into a dwg. Xref that into a design file (Grading Utility) just to see if everything lines up. (Roof Drains, steps, cleanouts) stuff like that. Again just a thought.
Civil3D 2020
Matt__W
  • I like my water diluted.
Re: Revit - Export Exteriors to 3D
« Reply #1 on: October 20, 2015, 03:43:15 PM »
Create a 2D view, turn off/hide the interior walls then use the info provided >>here<< to align to a civil drawing.
« Last Edit: October 20, 2015, 03:47:21 PM by M@yhem »
Autodesk Expert Elite
MSTG007
« Reply #2 on: October 20, 2015, 03:44:57 PM »
I guess that answers it. I do appreciate the links you provided earlier. This just came up and we are trying to make sure everything aligns up.
Civil3D 2020
« Reply #3 on: October 27, 2015, 12:26:05 PM »
and our you could use Navisworks to export those items and then import to Civil 3d....IBX file I think is the ticket
