Author Topic: Add/Modify BreaklineSet with own description  (Read 2383 times)
cadplayer
« on: October 18, 2015, 05:50:05 AM »
Hello!
Itīs a little confusing in COM-API is it possible to set a name for description
' Create the polyline basis for the breakline.
Dim o3DPoly as Acad3DPolyline
Dim dPoints(0 To 8) As Double
dPoints(0) = 1200: dPoints(1) = 1200: dPoints(2) = 150
dPoints(3) = 2000: dPoints(4) = 3000: dPoints(5) = 120
dPoints(6) = 3000: dPoints(7) = 2000: dPoints(8) = 100
Set o3DPoly = oAeccDocument.Database.ModelSpace _
  .Add3DPoly(dPoints)
o3DPoly.Closed = False
Dim oBreakline As AeccSurfaceBreakline
Dim vBLines As Variant
' This has to be an array, even if we only have one entity.
Dim oEntityArray(0) As AcadEntity
Set oEntityArray(0) = oAeccDocument.Database.ModelSpace _
  .Add3DPoly(dPoints)
Set oBreakline = oTinSurface.Breaklines.AddStandardBreakline _
  (oEntityArray, "Sample Standard Break" , 1#)
But not in Civil-API with C#.net
Tinsurface.BreaklinesDefinition.AddStandardBreaklines(ObjIdColl, 10, 5, 5, 0);
Is there a way to can manipulate description. I always get a name "Breakline Set..." I donīt like
BlackBox
Re: Add/Modify BreaklineSet with own description
« Reply #1 on: October 18, 2015, 11:01:13 AM »
AddStandardBreaklines() Method returns a SurfaceOperationAddBreakline object which provides a Description Property.
For reference:
http://docs.autodesk.com/CIV3D/2016/ENU/API_Reference_Guide/html/5897aaea-ff18-097a-ffda-25e84385826d.htm
http://docs.autodesk.com/CIV3D/2016/ENU/API_Reference_Guide/index.html
Cheers
cadplayer
« Reply #2 on: October 19, 2015, 03:59:37 AM »
Thank you, but I didnīt found an option to can set the description for a Breaklineset. In my code I tryed to.
If I read it works, but not if I write in TinSurface ?!
Is it maybe possible to add Breaklines to a defintion Breaklineset or to can modify I have to read all breaklinesets and than create it new with selected lines?
        public static IList<BreaklineSet> ReadBreaklineSet()
            IList<BreaklineSet> m_BreaklineList = new List<BreaklineSet>();
            Document acadDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            using (Transaction tr = acadDoc.TransactionManager.StartTransaction())
                foreach (ObjectId surfId in CivilApplication.ActiveDocument.GetSurfaceIds())
                    TinSurface surf = tr.GetObject(surfId, OpenMode.ForRead) as TinSurface;
                    if (surf != null)
                        SurfaceDefinitionBreaklines brkdefs = surf.BreaklinesDefinition;
                        for (int i = 0; i < brkdefs.Count; i++)
                            SurfaceOperationAddBreakline brklines = brkdefs[i];
                            for (int j = 0; j < brklines.Count; j++)
                                SurfaceBreakline brkline = brklines[j];
                                m_BreaklineList.Add(new BreaklineSet
                                    SurfOperAddBreaklDescr = brklines[j].Description,
                                    SurfDefBreaklDescr = brkdefs[i].Description,
                                    SurfBreakl = brkline
                tr.Commit();
            return m_BreaklineList;
cadplayer
« Reply #3 on: October 19, 2015, 04:15:33 AM »
    [DefaultMember("Item")]
    public class SurfaceOperationAddBreakline : SurfaceOperation, IEnumerable<SurfaceBreakline>
        public SurfaceBreakline this[int index] { get; }
        public SurfaceBreaklineType BreaklineType { get; }
        public int Count { get; }
        public string Description { get; set; }
        public double MaximumDistance { get; }
        public double MidOrdinateDistance { get; }
        public double WeedingAngle { get; }
        public double WeedingDistance { get; }
        public virtual IEnumerator<SurfaceBreakline> GetEnumerator();
        public IEnumerator GetObjectEnumerator();
        public ObjectIdCollection InsertIntoDrawing();
It must be possible to set description for a breaklineset or ?!
cadplayer
« Reply #4 on: October 19, 2015, 04:40:48 AM »
I get it:
        public void AddBreaklinesBySset()
            Surface surf = new Surface();
            surf.SelectTinSurface();
            ObjectIdCollection coll = Selection.SsetFilter("Layer1", "LWPOLYLINE");
            surf.Tinsurface.BreaklinesDefinition.AddStandardBreaklines(coll, 10, 5, 5, 0);
            SurfaceDefinitionBreaklines brkdefs = surf.Tinsurface.BreaklinesDefinition;
            SurfaceOperationAddBreakline brklines = brkdefs[0];
            brklines.Description = "Test";
huiz
  • Certified Prof C3D
« Reply #5 on: October 19, 2015, 08:25:25 AM »
I get it:
This way you asume there is only one breakline set. There are multiple breakline sets possible.
The function to add breaklines does not have a parameter for a description. Adding Drawing objects does have a function to add an ObjectIdCollection and a description at once. But breaklines does not. You can create a new breaklineset object, but that object does not have an option to add an ObjectIdCollection.
The best way you can do is adding a breakline set, and then you change the description of the last breakline set.
brkdefs[brkdefs.Count - 1].Description = "Test";
Of course inside a Try/catch, to be sure :-)
cadplayer
« Reply #6 on: October 19, 2015, 09:09:50 AM »
Yes thank you works fine for me.
What ar you thinking about manipulate a breaklineset, is it better to delete and create a new or is it possible to add breaklines to a defintion breaklineset?
Maybe you reply at last, so I think I have to read all Breaklinesets , get sort number (BreaklinePosition in Surface) and than create a new Breakline(definition) and move to same position in sorting all breaklinesets in surface
The question is, can I delete "one" Breaklineset in a Surface an create a new Breaklineset on same Position as before? Picture shows to remove alle Breaklines in a Surface with metod RemoveAt(0). But I have 2 or 3 SurfaceBreaklineDefinitions and want remove only number 2 for example. And than create a new Breaklineset on second Position
« Last Edit: October 19, 2015, 10:24:30 AM by cadplayer »
huiz
« Reply #7 on: October 19, 2015, 01:30:28 PM »
You cannot modify a breakline set so it is better to remove it and add a new one.
cadplayer
« Reply #8 on: October 22, 2015, 02:11:16 PM »
Thanks again, I get it.
