Author Topic: Exception Class  (Read 4718 times)
MexicanCustard
Re: Exception Class
« Reply #15 on: October 15, 2015, 02:16:19 PM »
This is the most basic example I can create explaining my previous post.
In your XAML:
<StackPanel Orientation="Horizontal" HorizontalAlignment="Right">
            <Button Width="75" Content="Cancel" Margin="5" IsCancel="True"/>
            <Button Width="75" Content="OK" Margin="5" IsDefault="True" Click="OkClicked"/>
</StackPanel>
In your code behind:
Code - C#: [Select]
  1. private void OkClicked(object sender, RoutedEventArgs e)
  2. {
  3.     DialogResult = true;
  4. }
Code - C#: [Select]
  1. var window = new myWindow();
  2. var result = window.ShowDialog();
  3. if (!result) //Return if they clicked Cancel or Closed the window
  4.     return;
  5.
  6. //Do something if they clicked OK
  7.
« Last Edit: October 15, 2015, 02:19:58 PM by MexicanCustard »
Keith Brown
Re: Exception Class
« Reply #16 on: October 15, 2015, 02:27:08 PM »
every time you do that Zod kills a little kitten.
Made me laugh.  ;D ;D
Re: Exception Class
« Reply #17 on: October 15, 2015, 10:08:26 PM »
Yep, Me too :)
shers
Re: Exception Class
« Reply #18 on: October 18, 2015, 11:50:59 PM »
Thanks all! It's solved. I had to handle it in the main.
