Author Topic: Exception Class  (Read 4719 times)
shers
Exception Class
« on: October 15, 2015, 12:46:34 PM »
I have an Exception Class as below.
using System;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace Test
    class MyException : Exception
I call this class as below
if (result == false)
                throw new MyException();
But I get an error that says 'Unhandled exception has occured in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Exception of type Test.MyException was thrown.
Please help.
Re: Exception Class
« Reply #1 on: October 15, 2015, 01:05:21 PM »
I believe you'll need to add constructors to the class
eg
https://msdn.microsoft.com/en-us/library/87cdya3t(v=vs.110).aspx
Re: Exception Class
« Reply #2 on: October 15, 2015, 01:08:16 PM »
every time you do that Zod kills a little kitten.
perhaps try something like :
if (!result)
shers
Re: Exception Class
« Reply #3 on: October 15, 2015, 01:24:16 PM »
eg
That doesn't make any difference.
Keith Brown
Re: Exception Class
« Reply #4 on: October 15, 2015, 01:25:56 PM »
You need to catch the exception once you throw it.
shers
Re: Exception Class
« Reply #5 on: October 15, 2015, 01:27:53 PM »
It was a way to exit the application from the class. Any other option?
Keith Brown
Re: Exception Class
« Reply #6 on: October 15, 2015, 01:31:01 PM »
You need to handle all exceptions.  Otherwise you will get an unhandled exception error.
Catch it in your calling method.
shers
Re: Exception Class
« Reply #7 on: October 15, 2015, 01:43:24 PM »
try
                if (!result)
            catch (Exception ex)
                throw;
Still the same. I don't want the execution to continue when throw new MyException is reached. That is, the execution should stop. Is there any other method.
MexicanCustard
Re: Exception Class
« Reply #8 on: October 15, 2015, 01:51:11 PM »
try
                if (!result)
                throw;
You're just re-throwing the exception within the catch.  Whats catching your exception above this?  If you keep throwing the exception it will bubble up to the operating system and you get the error dialog you posted.  If you put a breakpoint within your catch clause you should be hitting it.
shers
Re: Exception Class
« Reply #9 on: October 15, 2015, 01:54:40 PM »
Exception of type 'Test.MyException' was thrown. This is the error I get in the catch block
gile
  • Marseille, France
Re: Exception Class
« Reply #10 on: October 15, 2015, 01:55:21 PM »
What's the issue ?
You throw an exception and the host application (AutoCAD here) alerts you an exception occured. This is the way all exception work.
Re: Exception Class
« Reply #11 on: October 15, 2015, 01:59:00 PM »
Oh, wait !
You don't really want an exception thrown ; You want to return to main and exit if the test returns true ?? Yes ?
shers
Re: Exception Class
« Reply #12 on: October 15, 2015, 01:59:46 PM »
Exactly! I call a wpf window with an OK and Cancel button, from a class. When the user clicks on the Cancel button, the code should exit. Instead, it continues to execute. To avoid this, I call this MyException class, so that it simple exits. Is there any other way to quit the application if the user clicks on the Cancel button?
Re: Exception Class
« Reply #13 on: October 15, 2015, 02:03:32 PM »
Yes, just close the wpf and return to main.
MexicanCustard
Re: Exception Class
« Reply #14 on: October 15, 2015, 02:10:12 PM »
Set the IsCancel property on your cancel Button to true that will handle the cancel button.  Unless you need to do some cleanup within the window, which you shouldn't be doing.
For the Ok button set the windows DialogResult property to true that takes care of that button.
