Author Topic: Converting Polyline Segment to Curve  (Read 3004 times)
MSTG007
« on: October 05, 2015, 08:48:03 AM »
Just curious here, is there a faster way to convert a polyline segment to a curve?
I don't know what peoples workflow for that is, but I usually click the polyline segment; Click on the Middle vertex and wait a second or two for the popup to show up; click  Convert to Arc; then use the nearest command and boom.
Again just asking around.
Civil3D 2020
Re: Converting Polyline Segment to Curve
« Reply #1 on: October 05, 2015, 09:33:50 AM »
That is my workflow as well. Although I don't click the middle, I just hover over it. Then I don't "wait a second or two", as the context menu displays immediately. Before this grip edit function was available I used a small lisp I wrote that would add a Bulge factor of 0.25 to selected segments, which I would then go back and edit using the 'near osnap...so very similar steps for as far back as I can recall.
« Reply #2 on: October 05, 2015, 10:32:14 AM »
fillet
« Reply #3 on: October 05, 2015, 10:39:09 AM »
fillet
You can't fillet a single segment.
Select first object or [Undo/Polyline/Radius/Trim/Multiple]:
Select second object or shift-select to apply corner or [Radius]:
Cannot fillet an entity with itself.
« Reply #4 on: October 05, 2015, 10:53:45 AM »
There is also this by ElpanovEvgeniy.
ribarm
  • Marko Ribar, architect
« Reply #5 on: October 05, 2015, 01:09:57 PM »
I've improved those to be applicable to all Views/Ucs in 3d space...
Look here...
Regards, M.R.
M.R. on Youtube
MSTG007
« Reply #6 on: October 06, 2015, 07:09:41 AM »
Lee I think you nailed it, specially when you add that to a right click mouse menu popup. ALOT faster. Thanks guys for the brainstorming!
Civil3D 2020
« Reply #7 on: October 06, 2015, 07:39:05 AM »
All credit to Evgeniy!  :-)
