Author Topic: Hide() winform, when pressing escape (error-message)  (Read 1453 times)
cadplayer
« on: October 05, 2015, 02:32:38 AM »
Hello!
I would like catch an Escape-event in case I press a button "Select", the winform hides and I can select someone. But if I donīt select as I press escape-key I get a error-message.
I try it to catch the Formclosing-event, it works, but first I get Autocad-error-message and than it comes formclosing-message. Have somebody a trick to solve it better ?
cadplayer
Re: Hide() winform, when pressing escape (error-message)
« Reply #1 on: October 05, 2015, 07:28:47 AM »
I get this message if I press "Escape" in the method
try
                PromptEntityOptions options = new PromptEntityOptions("\nSelect a Surface: ");
                options.AllowNone = false;
                options.SetRejectMessage("\nThe selected object is not a Surface.");
                options.AddAllowedClass(typeof(CivSurface), false);
                PromptEntityResult result = ed.GetEntity(options);
                if (result.Status == PromptStatus.OK)
                    this.SurfaceId = result.ObjectId;
                if (ObjectId.Null == SurfaceId)
                    ed.WriteMessage("\nNo TIN Surface object was selected.");
            catch(Exception ex)
                ed.WriteMessage("\nClose Program");
MexicanCustard
« Reply #2 on: October 05, 2015, 10:21:53 AM »
Where are you assigning SurfaceId if the promptresult is anything other than Ok?
cadplayer
« Reply #3 on: October 22, 2015, 02:12:27 PM »
Yes thatīs clear - thank you!
