Author Topic: Topics for a VBA Tutorial  (Read 19975 times)
David Hall
  • Automatic Duh Generator
« Reply #30 on: May 04, 2005, 03:05:36 PM »
MP, its funny that you sent me there, b/c I read that just this morning.  Whats also funny is I teach by that very principle.  What I meant about being a hacker is I have no formal trainging in VB(A) so the methods I will be showing are what I know. (Which is sometimes not the best way to get the job done)  Also, I dont program for a living, so by someothers standards, that makes me a hacker not a programmer.  Either way, I dont care, because if it helps me get my job done faster or more efficiently, its a program.
daron
« Reply #31 on: May 04, 2005, 03:08:14 PM »
And if teaching it helps you get better knowledge, then you become a better hacker/programmer.
David Hall
« Reply #32 on: May 04, 2005, 03:10:28 PM »
Quote from: Daron
Exactly!!!
« Reply #33 on: May 04, 2005, 08:57:14 PM »
here, here. According to some people there are only the the 2 clubs.
Personal Opinion : Programming is about solving problems. You solve problems, therefore ...
< deleted derogarory remarks about some academics >
David Hall
« Reply #34 on: May 05, 2005, 09:33:21 AM »
KWB - Thank You
jonesy
  • SuperMod
« Reply #35 on: May 06, 2005, 07:09:49 AM »
OK, getting back on track, would it be easy to create a proggy that can issue a save every 10 commands? Could this be covered in a course?
« Reply #36 on: May 06, 2005, 10:07:29 AM »
Tracey, that would be a simple program in VBA ...
hyposmurf
« Reply #37 on: May 06, 2005, 11:53:48 AM »
Not only simple but dam handy. :)
ML
« Reply #38 on: May 06, 2005, 03:02:38 PM »
Has anyone tried applying VBA in other programs? I have several macros in Excel as well and quite frankly, enjoy it more then CAD at times.
The irony is that it helps me approach programming better in AutoCAD.
Anyone who is in this forum is very fortunate. I have learned a bit from different people and a lot from others.
I still have a long way to go but I have also come a long way in VBA. So anyone in this forum (with persistence) can learn just as I am.
David Hall
« Reply #39 on: May 06, 2005, 03:11:56 PM »
OK, this is jumping ahead, but here is that program.  I will have to look to see who gets credit for this.
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
'***Below code is to AUTO save the drawing every 25 commands,
  If ThisDrawing.GetVariable("DWGTITLED") = 1 Then 'don't use on new, unsaved drawings
  Select Case CommandName
    Case UCase("undo"), UCase("u"), UCase("zoom"), UCase("z"), UCase("pan")
        command_count = command_count
    Case UCase("QSAVE"), UCase("SAVE")
        command_count = 0
    Case Else
        command_count = command_count + 1
        If command_count = 25 Then 'change this to any number you want
            ThisDrawing.Save
            command_count = 0
        End If
    End Select
  End If
End Sub
David Hall
« Reply #40 on: May 06, 2005, 03:13:57 PM »
Jeff_M gets credit for that module.
« Reply #41 on: May 06, 2005, 03:16:09 PM »
That's Jeff Mishler in case anyone wants to know. An excellent programming lad that wears a white hat.
ML
« Reply #42 on: May 06, 2005, 03:17:43 PM »
Did everyone want too turn this into a code posting post? Or are we going to stick to basic theory?
David Hall
« Reply #43 on: May 06, 2005, 03:17:55 PM »
It needs to be placed in the ThisDrawing module of the Acad.dvb (or any dvb that will always be loaded)  For those of you who do not know where that is, I will be covering that in an upcoming handout.
David Hall
« Reply #44 on: May 06, 2005, 03:18:52 PM »
I am putting together handouts that will cover the theory, but by people posting code, we can use those examples in our discussions.
