Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
CAD Forums
CAD General
Topic:
Change Xref Layer Linetype
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Change Xref Layer Linetype (Read 1588 times)
MSTG007
Gator
I can't remeber what I already asked! I need help!
on:
September 22, 2015, 08:22:01 AM »
Is there a way to change an xref layer name linetype using a script file?
Logged
Civil3D 2020
Needs a day job
Re: Change Xref Layer Linetype
Reply #1 on:
September 22, 2015, 08:37:56 AM »
Yes .. use -layer, or vla-put-linetype, or entmod. Just make sure the linetype is loaded first.
Logged
MSTG007
Gator
Reply #2 on:
September 22, 2015, 08:47:22 AM »
So if I have a layer that is in a xref called SAWCUT that has a linetype that is HIDDEN. My script would look life:
Code:
[Select]
-la
s
*|*sawcut
lt
continuous
When I do that I get an invalid layer name.
Logged
Civil3D 2020
Needs a day job
Reply #3 on:
September 22, 2015, 10:02:52 AM »
Code - Auto/Visual Lisp:
[Select]
defun
foo
pat lt
l n
while
setq
l
tblnext
"layer"
null
l
if
and
wcmatch
strcase
setq
n
cdr
assoc
2
l
strcase
pat
setq
n
tblobjname
"layer"
n
entmod
subst
cons
6
lt
assoc
6
entget
n
entget
n
;; (foo "*|*sawcut" "Continuous")
Logged
MSTG007
Gator
Reply #4 on:
September 22, 2015, 10:35:11 AM »
Awesome Job! Thank you a lot!
Logged
Civil3D 2020
Needs a day job
Reply #5 on:
September 22, 2015, 11:16:15 AM »
Logged
Print
Pages: [
1
Go Up
« previous
next »
CAD Forums
CAD General
Topic:
